1989 E150 302 Water Pump Bolts - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 03-08-2011, 01:26 PM
rickm15752 rickm15752 is offline
rickm15752 is starting off with a positive reputation.
Hi everyone,
I'm replacing the water pump on my E150. This is the 2nd time I've done this within the past 12 months. I've replaced water pumps before but this one developed a leak. I think I failed to torque the bolts sufficiently.
What I would like to find is a reference photo or diagram showing the location of the (4) studs and the (3) hex head bolts. I took a photo before I removed the pump. But, I'm not sure they were correctly placed to begin with.
I have an exploded view of the engine that shows the water pump and I clearly see two of the hex head bolts. I think there is a third bolt shown but it is quite small.
Thanks for your time.
Rick
89 2.9 w/water in oil alleyoopster Ranger & B-Series 14 07-10-2016 08:42 PM
5.8 Water Pump/Timing Cover Bolts & Stud Positions/Dimensions (Inside) Scndsin 1987 - 1996 F150 & Larger F-Series Trucks 4 05-30-2016 12:58 AM
Water Pump Leak Avid_Stroker 1994.5 - 1997 7.3L Power Stroke Diesel 11 05-29-2014 07:14 PM
Aftermarket Water Pump/Timing Cover Bolts: Stainless Steel or Chromemoly? Nightrain Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 02-05-2007 01:57 PM
Stripped out HFCM bolt???? Redeyeracing 6.0L Power Stroke Diesel 45 07-21-2005 10:59 AM
Tags
1989, 302, bolt, bolts, e150, exploded, ford, locations, pump, size, torque, truck, view, water, waterpump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
