1992 E250 5.8 Fuel Pressure reading? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 03-08-2011, 12:47 PM
RonaldD RonaldD is offline
RonaldD is starting off with a positive reputation.
I have a 1992 E250 with a 5.8 and apparent fuel issues. I tested the fuel pressure and found 44 PSI without vacuum and 35 PSI with vacuum at a normal idle. Everything I have found with that kind of detail tells me I should be seeing about 39 PSI without vacuum and about 30 PSI with vacuum.
What should it be for my van? This sounds like too much variation. Since most regulators I have found cover a wide range of trucks, I suspect if I replace the fuel pressure regulator I will get 39 PSI. Is this enough of a change to cause a problem?
Old 03-08-2011, 07:16 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like your Fuel Pressure Regulator (FPR) is OK.
You should get around 45 PSI reading with the vacuum line off and depending on your vacuum you should get 32-34 PSI at idle.
I do not know where you seen the 39 & 30 but who ever said it was wrong.
You vacuum may be a little low or your engine was idling a little high.
Most 5.8L engines will did at between 28-30 PSI fuel pressure.
Every one that I have worked on and others I have worked with the above is true and not what the book says below.
ENGINE RUNNING 30 - 45 PSI
KEY ON, ENGINE OFF 35 - 45 PSI
I do not know how they would come with those readings.
Old 05-30-2013, 01:35 PM
ricksrideshelper ricksrideshelper is offline
ricksrideshelper is starting off with a positive reputation.
my pressure stays aT 20 psi until u crank it over then steadily climbs to about 50 . stop turnin it over then it comis back down to 20 . i just replaced fuel pump with one that i knew worked abd now it does what i said above . what else can i check
Fuel pressure question musicars 1987 - 1996 F150 & Larger F-Series Trucks 2 10-27-2014 04:48 PM
Can my fuel regulator be weak? kevin206 1987 - 1996 F150 & Larger F-Series Trucks 2 08-19-2014 12:05 AM
1996 F250 5.8 fuel pressure issue digicon 1987 - 1996 F150 & Larger F-Series Trucks 12 02-22-2014 04:30 PM
In tank fuel pump spec?? dustmote 1968-2013 Full Size Vans 4 11-20-2011 07:50 AM
Fuel Pressure Test Results - Seeking Interpretations & Recommendations PaulDH 1987 - 1996 F150 & Larger F-Series Trucks 16 05-22-2010 05:15 PM
Tags
1992, 58, 58l, 92, 94, 95, buy, e250, econoline, f150, f250, ford, fuel, pressure, regulator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
