Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 03-07-2011, 10:53 PM
szotty szotty is offline
Garage is empty, add now
szotty is starting off with a positive reputation.
2007 ford edge how to get stretch fit belt on the pulleys?
i can get the alt,ac and cranksft belt on and off fine its the power steering to crankshaft. i have a clicking noise every time the belt goes around and i dont want my fiance out on the road if the belt goes, so woundering if anyone has replaced it and has tips on doing so very tight location. the car has only 36000 miles and just replaced rear wheel hub and front brakes with in the last 2000 miles and begining to not trust car cus things keep breaking.
__________________
'03 f250 scsb 4x4 frx gen-2,hpx,6637,derale transmission cooler,intank mods,harpoon,zoodad,ccv,door seal-mod, leveling kit, monroe magnum shocks,285's,4in turbo back exhaust,edge ezf1000, glow shift guages(boost,trans. temp,egt), oil bypass filter
  #2 (permalink)
Old 05-07-2011, 11:30 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
Their 2010 Ford Flex 3.5 listings:
Gates Part Locator & Interchange
The tool:
Gates Online Catalog
Tool detail:
FullPageLoader
The belt
belt detail:
FullPageLoader
Gates.com says you need a tool to install the belt. They also make belts to fit the water pump used on the 3.0 in the Escape, which needs no tool to install, and is non-adjustable.
tom
Well, I lied. Gates throws away something... When I tried the links, I got bupkis. Search Gates.com automotive aftermarket. The belt is stretchy and you need a tool.
as noted:
Product ID 74680016
Part # 91030
Product Description 91030 STRETCH FIT TOOL
UPC 072053538656
the belt:
Product ID 85560011
Part # K040357SF
Product Description K040357SF STRETCH FIT
UPC 770075417743
Category Hierarchy
Automotive -> Belts -> Micro-V® Stretch Fit® Belts
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
Tags
07, 2009, belt, edge, fit, ford, howto, noise, power, ps, pulley, replacement, stech, steering, stretch, stretchy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
