Unique IPR valve problem. HELP! - Ford Truck Enthusiasts Forums
Old 03-07-2011, 07:32 PM
NYC F-350's Avatar
NYC F-350 NYC F-350 is offline
NYC F-350 is starting off with a positive reputation.
I just installed a new HPOP and upon reinstallation of the IPR valve, something is not quite right. The connector is now pointed up close to the exhaust inlet to the turbo after it is torqued to spec.
Anyone have a clue why? Did I screw up?
Pic below to show the concern:
It now points upwards, where before it pointed downward and slightly towards the front of the truck. If I have to remove it, I do have an extra o-ring.
Old 03-07-2011, 07:36 PM
starrs starrs is offline
starrs is starting off with a positive reputation.
Just turn the connector back where you need it. It spins.
Piolet's Avatar
Piolet Piolet is offline
Piolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to behold
Mine points straight up.
Old 03-07-2011, 07:38 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Have you tried just twisting it to re-clock the connector? The IPR body will rotate on the valve.
Old 03-07-2011, 07:40 PM
NYC F-350's Avatar
Quote:
Thank you guys for responding so quickly!!
Heres the rub, I can not spin it. It will not budge!
Piolet: How long has it been that way? No problems with it being like that?
Old 03-07-2011, 07:45 PM
Piolet's Avatar
I don't know how long it's been that way. The oasis report showed that the last owner did all work at the dealer but there's no mention of any work on the IPR and I haven't done it. I'm at 213,000 miles now and no issues I know of related to IPR ... my new knocking issue ... that's a whole other thing
Old 03-07-2011, 07:50 PM
NYC F-350's Avatar
Ok, thanks. Made me feel better about it. I hope you figure out that knocking going on soon!
Thanks to all who replied so quickly.
Old 03-07-2011, 08:07 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
The IPR valve on 2003 engines (like Piolet's truck) is supposed to point at the 12 o'clock position. On late-build 2004 and up trucks such as NYC F-350's truck, it points at the 4 o'clock position. And yes, the IPR valve is supposed to spin independently of the hex (otherwise we wouldn't be able to install our IPR sockets on it to remove/install it). Hope this helps.
Old 03-07-2011, 08:11 PM
Piolet's Avatar
Thanks m-chan .... that's the little nuggets of info this site is great for.
Now shameless plug for my own post ...
http://www.ford-trucks.com/forums/10...placement.html
any ideas m-chan?
Old 03-07-2011, 08:17 PM
m-chan68's Avatar
any ideas m-chan?
Make sure all three FICM connectors are plugged in properly, since you mention one of the lock tabs are broken off. Otherwise, yeah that sounds like the typical 6.0L cold start stiction, if it clears up when the engine warms up.
Old 03-07-2011, 08:23 PM
NYC F-350's Avatar
Quote:
Thank you m-chan68 for posting up!
I removed the valve and was able to spin it enough to get it orientated in the correct position. I just had visions of total failure by twisting it that hard.
My first time in this far, thank you all for the reassurance.
Love this site!!!
Old 03-07-2011, 08:30 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
if you spray them down with some wd40 and spin them to lossen them up a little they are not as bad to align
Old 03-07-2011, 08:37 PM
djanzen's Avatar
djanzen djanzen is offline
djanzen is gaining momentum as a positive member of FTE.djanzen is gaining momentum as a positive member of FTE.
the solenoid is a completely separate piece from the ipr valve remove the nut and washer off the end and you can pull the solenoid right off and clean both pieces with a scotch brite pad and then the contact is better and it is easily moved. just when you tighten the nut it only needs about 15-20 inch pounds of torque!! just enough to prevent it from turning
New issue - hot no start Headviking 6.0L Power Stroke Diesel 21 09-15-2015 05:51 PM
What now?????? rigrunner 6.0L Power Stroke Diesel 40 09-15-2012 03:02 PM
IPR Valve BobbyB 6.0L Power Stroke Diesel 7 01-12-2011 02:24 AM
IPR Screen? mohle 6.0L Power Stroke Diesel 4 10-31-2010 12:24 PM
Main cause(s) of repeated IPR failure? pkins 6.0L Power Stroke Diesel 20 09-21-2009 07:52 PM
Tags
2006, 60, 73, diesel, f350, ford, ipr, location, pointed, powerstroke, problems, removing, troubleshoot, turbo, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
