92 F150 300--6 misses
To begin with...my truck was missing just a little..that i figured i might as well do some plugs and wires..im sure you all probably think of excuses too, to be able to work on your trucks anyways, threw on some plugs...some wires. i start it up and when its cold..runs fine but when it warms up it would missfire so bad..so i check the firing order, its ok..i check the plug gaps, about 4 of em were way off...my dad helped me and didnt gap any of them. well after 3 tries of messing with the stupid gaps...i make SURE SURE SURE the gaps were good, i checked the distributor cap, popped it off to check things out...looked ok. it is STILL missing, same thing just not as bad...fine when its cold..when its warm it misses. what am i missing and what could i check?
ahhhhh! the wire on cylinder #4 wasnt right, could see the sparks when the engine was idling rough :/ took it off and recrimped it and its all good. i cant believe i missed that. I also think the wire goin to the coil was messed so thanks for pointing that out to me...and my gapping was right on
bobj49f2
20
05-15-2012 10:35 PM
SPLabar
02-25-2000 02:03 PM
