07 F150 with IWE issues - New twist - Ford Truck Enthusiasts Forums
Old 03-07-2011, 05:42 PM
gcozmo's Avatar
gcozmo gcozmo is offline
gcozmo is starting off with a positive reputation.
I have an 07 F150 which I have had since new. It has approximately 25K miles on it. Last week after a big rain I noticed that the 4x4 was trying to engage and I got the TERRIBLE grinding noise that lasts about 10 seconds or so and quits. Well with the truck still being under warranty I took it to the dealer to repair, well the first day they couldn't duplicate the problem and had no codes. Well today they call me and tell me that the "shift motor is falsly engaging and they are going to replace it". Have any of you heard of this being the cause of the front hubs trying to engage on their own???
Old 03-09-2011, 10:57 AM
jimmyv13 jimmyv13 is online now
jimmyv13 has a very good reputation on FTE.jimmyv13 has a very good reputation on FTE.jimmyv13 has a very good reputation on FTE.
HAHA, ask him for the old shift motor when you get the truck back. I'm interested in what they say since these trucks use a vacuum system to engage the 4WD.
Old 03-09-2011, 08:51 PM
gcozmo's Avatar
I didn't think to ask for the old part. The way I understand it that if the shift motor is "hunting" for position that it may make the same noise as a IWE.
"pinpoint test found transfer case shift motor hunting for position, replaced and retested"
That is the actual quote on the repair ticket. The first day they had it they couldn't get it to make any noise but the second day they could. They also said that there was a code came up on the second day that wasn't there before. I think it was 50 but not sure about that. I picked it up at noon today and have driven it all over the place and NO noise so far.
Old 03-09-2011, 09:10 PM
I have been reading up on this. My '04 F150 made a grinding noise randomly and the tech said the only thing that could do that was the IWE's. He never even mentioned the transfer case motor and said the 4WD system was completely and entirely controlled by vacuum.
Old 03-10-2011, 12:44 PM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
I wouldnt think that your transfer case shift motor would make those sounds. Sounds like a vacuum leak in the IWE system somewhere. I would get a vacuum guage and check your system. Also i think that if your shift motor was trying to engage your 4x4 light would be coming on and off, i could be wrong but that is what engages the light is the motor. Keep and eye on it.
Old 03-10-2011, 12:50 PM
gcozmo's Avatar
Quote:
Good point. I didn't think about the light. I wasn't to sure about the diagnosis myself but this dealership is really good about diagnosing and repairing and thats the only reason that I believe them. So far I have driven about 100 miles in the rain and cold and everything else and no problems, lets just hope it stays that way!!
Old 03-10-2011, 01:09 PM
Sounds like you've got yourself a good local dealer...
Old 03-10-2011, 02:35 PM
442w30 442w30 is offline
442w30 is starting off with a positive reputation.
Glad to hear they fixed it...you cant get old parts if they are being replaced under warranty as usually they have to be kept in case the factory wants to look at them.
Old 03-10-2011, 02:43 PM
xjcamaro89's Avatar
Like i said, i could be wrong and they could be right. Hope that was the fix!
Old 03-10-2011, 05:34 PM
gcozmo's Avatar
Thanks for the vote of confidence!! Only time will tell.
07 f150 4x4 no light on but 4 wheel drive on hermangarza 2004 - 2008 F150 4 08-26-2014 08:03 PM
fan clutch source for 78 400 fatherdoug Cooling, Heating, Ventilation & A/C 14 06-29-2014 06:24 PM
2001 Screw 4WD not engaging dispatch55126 1997 - 2003 F150 4 01-05-2014 08:09 PM
94 f150 clutch will not engage craigswanson 1987 - 1996 F150 & Larger F-Series Trucks 3 10-26-2010 10:41 PM
4x4 not engageing J.W. Offroad & 4x4 3 12-25-2009 03:12 AM
Tags
2004, 20042008, 2007, 4x4, case, dealer, f150, fix, ford, issue, issues, iwe, long, problems, promble, shooting, transfer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
