Use aftermarket intake with feedback carb?
Would it makes sense to use an after market intake manifold with a stock feedback carb? I'm in the process of putting my 85 F150 w/ 300 and stock feedback system back to the best it can be. I have changed the O2 sensor and corrected a few other issues and now have what I think to be a decently running feedback system. I averaged over 18mpg during a 100 mile trip crusing over 70mpg and about 30% town driving last weekend.
I'm looking to get the best torque and mileage out of the engine as possible so keeping the single barrel with electronics isn't a problem.
I don't think you'd gain much from it performance wise (maybe a little, but the 1bbl would limit you). But there are some emissions components that wouldn't be compatible with the 4bbl intake, such as the EGR spacer underneath the carb.
I also don't think there is (although there may be) an adapter to let you put a 1bbl carb onto a 4bbl intake. You'd probably have to go from a 1 - 2 adapter, and then bolt that onto a 2 to 4bbl adapter.
What is your reasoning behind wanting to use one if you're sticking with the 1bbl?
Just playing with ideas.
The EGR is vacuum controlled and not monitored by the computer as far as I can tell. It was disconnected until yesterday when I traced as many vacuum lines as I could and reconnected them.
I'm curious if doing some of the normal performance mods would help a stock intake, ignition system. I
MatthewRadio
18
03-04-2010 09:30 PM
MatthewRadio
401, 477, & 534 SD Engines
02-23-2010 02:23 PM
HundredBuckTruck
08-22-2004 12:46 PM
Wishbone
02-25-2003 05:43 PM
300, 300i6, aftermarket, carb, carburator, carburetor, carburettor, feedback, ford, i6, intake, manifold
