ABS & Brake light on - Ford Truck Enthusiasts Forums
Old 03-07-2011, 03:55 PM
blee1ash blee1ash is offline
blee1ash is starting off with a positive reputation.
I have a '97 f-250 with the rear wheel abs. Both the abs light and the brake warning lights are on. Brake fluid level is good and not leaking anywhere. The brakes work fine, but I can tell the abs is not working, not that the abs worked will in the first place.
I tried unplugging and cleaning the wire connectors near the master cylinder, and took the sensor out of the rear diff. and cleaned it. The lights are still on.
Any Ideas what the problem might be?
Does anyone know how to get trouble codes from this abs system?
I thought about disconnecting the abs and removing the warining bulb from the dash, but the red brake warning light is on also and I would like to have that one working incase I ever loose brake fluid.
Old 03-07-2011, 04:36 PM
planehunter's Avatar
planehunter planehunter is offline
planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.
They make a special reader for ABS systems. IMO I would take it to a mechanic with a reader because you may have to have the system bled and then reset.
Old 03-07-2011, 05:01 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
http://www.ford-trucks.com/forums/73...abs-codes.html Have a read through this link for how to get the RABS trouble codes.
However my guess would be that the fluid level sensor is bad but just a guess.
Old 03-07-2011, 06:11 PM
Thanks for the help. I'll try to pull the codes and go from there.
Old 03-08-2011, 12:25 PM
I pulled the codes today. Got code 4, according to my chilton manual = rabs valve switch closed. The manual has very little info on the abs system.
Any iedas?
Old 03-08-2011, 12:55 PM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
I just had the same symptoms and the same code thrown as you a couple months ago. I had the valve replaced and all is good in the world again
no ABS brakes and no warning light mike L 1987 - 1996 F150 & Larger F-Series Trucks 0 02-27-2016 05:57 AM
ABS light ReBilld 1994.5 - 1997 7.3L Power Stroke Diesel 38 07-16-2015 07:16 PM
96 F150 ABS and brake warning light on artsamm 1987 - 1996 F150 & Larger F-Series Trucks 2 10-23-2013 01:19 AM
93 ABS Issue--Slightly urgent:) v8xploder 1978 - 1996 Big Bronco 3 06-25-2011 10:18 PM
97 ABS light on Ohio Ford Farm Ranger & B-Series 7 09-20-2009 09:30 PM
Tags
1996, 2000, 2003, 2007, abs, brake, dies, f150, f350, ford, light, lights, ranger, starts, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
