Rear End Width? - Ford Truck Enthusiasts Forums
Rear End Width?
Old 03-07-2011, 02:04 PM
vandorin123's Avatar
vandorin123 vandorin123 is offline
vandorin123 is starting off with a positive reputation.
Question Rear End Width?
Alright, ive done a lot of hunting online and im not finding what im looking for and hoping that someone can help me here. I would measure my own axle, being as though i own a 93 f150 with an 8.8, only problem with that is it's sitting at my father's place in missouri with a messed up motor (massive water leak from screw type holes on my block located on the side but behind the passenger side head, also if you have any idea why water would be pouring out of that hole you can help me with that too! Uhg because im completely stumped there) and i live in iowa. Sooo i need the wheel mounting surface to wheel mounting surface width of an 8.8 out of a 92-96 f150.
Im toying with some long term ideas for my truck. I know that the engine carriage out of a 01+ crown vic will fit perfectly between my frame rails, only having to worry about mounting and then things like steering linkage. Basically obtaining a arm style independant front suspension, rack and pinion steering, a 5x5 bolt pattern (which opens up my options for wheels to an all new level), an astounding drop, and motor mounts for a newer 4.6/5.4
Yes I said 4.6/5.4, im wanting to drop a healthy 5.4 (possibly supercharged, haha) in my 93 f150. I want something different, if you havent been able to tell yet.
Now for the reason im wanting to know the rear width...well lets just say that i know that the wheel mount surface to wheel mount surface of a newer mustang IRS system is 62" if you catch my drift haha
Anyways if any of you cal help me with those two problems it would be greatly appreciated! Also tell me what you think about my crazy plan
Old 03-08-2011, 10:01 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
My research indicates the approximate WMS to WMS dimension is 65 1/8"
Interesting project you have there!
Old 03-18-2011, 02:10 AM
Thank you a bunch, just what i was looking for. Some differences in width, all is still just in thought though. Anyways thanks for the help!
Old 03-18-2011, 09:53 AM
rla2005's Avatar
Anytime, glad to help out.
some crown vic IFS install questions drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 12-18-2016 10:42 PM
How Wide is '88 F150 rearend? 37 Ford guy 1987 - 1996 F150 & Larger F-Series Trucks 5 07-23-2009 07:39 AM
1998 F150 4.6-5.4 swap F0rdFre@K 1997 - 2003 F150 29 12-20-2008 09:19 PM
Sterling 10.25" SRW Axle Width, 92 F350 4x4 Pickup? SoCalDesertRiders Clutch, Transmission, Differential, Axle & Transfer Case 0 07-30-2008 10:18 AM
more 9" meaurement geekism havi 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 02-17-2008 03:57 PM
Tags
1993, 1996, 1997, 2003, 88, 9296, diminsons, end, f150, f350, ford, rear, specs, truck, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
