somebody please help about to give up and scrap truck
ok the truck is a 1989 ford f250 standard cab 5 speed 4.9l the truck will run but always acting like its running outta gas always bucking and hesitating violently i have replaced the following parts both fuel pumps in the tanks fuel pump on the rail and filter all the fuel lines even new injectors new plugs wires caps and distributor theres no vacum leaks and i have good even compression on all cylinders and when the truck runs its extremely rich smelling and idles horribly like it wants to stall imguessing maybe fuel pressure regulator is done cus theres no difference when i remove the vacum line from the regulator with the truck running please someone help
on
Sputtering
1. The first sign of a faulty fuel pressure regulator is when the engine sputters or stumbles as it runs. This often manifests itself as a heavy vibration as the engine accelerates.
Trouble Starting
2. Often times, cars with bad fuel pressure regulators will have trouble starting when they have not been running for a while. This is most noticeable if it persists for multiple mornings over a long period of time.
Noisy Pump
3. Faulty pressure regulation can lead to a noisy fuel pump. This is the common result of the fuel line attempting to inject too much gasoline into the engine, making the pump louder than normal.
Spark Plug
4. Spark plugs used with engines with bad fuel pressure regulation will often become fouled. Fouled spark plugs will show thick deposits on the contact surface.
Mileage
5. The biggest indicator of a bad fuel pressure regulator is a noticeable drop in gas mileage. This results as more and more fuel than is necessary is forced into the engine and burned up at an increasing rate.
Trouble Starting
Noisy Pump
Spark Plug
Mileage
Does the speedometer jump arround when it sputters?
