New PCM Recal. 11B23 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 03-07-2011, 10:38 AM
Eric326 Eric326 is offline
Eric326 is starting off with a positive reputation.
Just happened to come across this information while I was at my dealer having my CAC changed out, it showed up on oasis. This applies to all super duties REGARDLESS of mileage. The new PCM flash is marked for addressing these concerns:
"In order to avoid potential time consuming and costly service repairs, Ford has developed calibration improvements to the Powertrain Control Module (PCM) for your vehicle with improved fault detection capabilities. This will allow the vehicle to quickly detect and react to issues before significant damage occurs. Some examples include water-in-fuel reduced power mode, engine coolant temperature monitoring, over-full engine oil level, and proper circulation withing the engine oil cooler. Your dealer will provide more detailed information after the service is complete."
I figured I would post this up in case anyone was interested in getting their truck flashed. Also, this customer satisfaction program is marked for letters to be mailed to owners to notify them of this update. But, if anyone would like a copy of the letter just message me and I can scan and email you a copy.
Old 03-07-2011, 11:23 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
thanks for the letter!
Old 03-07-2011, 11:26 AM
Quote:
No problem, I figured there'd be a few people out there who might want a copy. I wish I had more answers on the programming behind the PCM flash, specifically how the PCM is going to monitor oil-overfull conditions more closely. Either way the programming sounds positive and I will have my truck back in a couple hours from getting the flash and CAC changed out. I'll post if I notice any other differences with the flash.
Old 03-07-2011, 12:07 PM
senix's Avatar
This is so new it is not listed anywhere else. I did a seach on NTSHA
Old 03-07-2011, 12:37 PM
2010F350 2010F350 is offline
2010F350 is starting off with a positive reputation.
Yeah I called my dealer here in Canada. They have a letter as well but they dont have the update.
Old 03-07-2011, 12:56 PM
senix's Avatar
CSB 11B23 letter
Here is the letter:
Old 03-07-2011, 01:02 PM
Yeah, normally I try to keep up to date on this stuff but this one caught me off guard. And you can notice the letters are dated for March 2011, so at max maybe 7 days old Ford has issued this notice officially. I wouldn't have seen it if I didn't have them pull up my OASIS, but once inside OASIS my truck was immediately flagged for the bulletin.
Old 03-07-2011, 01:03 PM
Thanks for posting up the letter as a link senix.
Old 03-07-2011, 02:04 PM
smotrs's Avatar
smotrs smotrs is offline
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
Thanks for posting Scott and thanks for the heads up Eric.
Old 03-07-2011, 02:32 PM
jimd1050's Avatar
jimd1050 jimd1050 is offline
Worry later? IT IS LATER!
jimd1050 has a very good reputation on FTE.jimd1050 has a very good reputation on FTE.jimd1050 has a very good reputation on FTE.
Latest and Greatest?
I'll bet that's what they did to me Scott - you remember they told me it wasn't even released yet? They never did give me the data on it though.
Old 03-07-2011, 02:42 PM
senix's Avatar
Jim,
Makes sense. I guess time will tell.
Old 03-07-2011, 03:01 PM
jimd1050's Avatar
Jim,
UPS shows a package from Cerritos, CA arriving Wednesday by end of day -
Old 03-07-2011, 04:05 PM
smotrs's Avatar
Quote:
Jim, your gonna have to change your avatar so it's not as dark, maybe off white.
Old 03-07-2011, 07:42 PM
caprang's Avatar
caprang caprang is offline
caprang is gaining momentum as a positive member of FTE.
Very interesting. I wonder if anything else will change with the new programming. I recall some older flashes showed the "cleaning exhaust filter" message while others dont. It will be interesting to see the feedback from those getting this done early.
Old 03-07-2011, 07:43 PM
caprang's Avatar
Oh, the "cleaning exhaust filter" was meant as an example of things that changed in the flash but werent highlighted, not meant to start a different conversation.
how to test - 11B23 calibration update - oil over filled speakerfritz 6.4L Power Stroke Diesel 0 08-03-2016 01:05 PM
Would dealer update latest PCM strategy on engine pull? diesel_dan 6.0L Power Stroke Diesel 11 04-26-2016 10:21 AM
Customer Satisfaction program 12B33 OPTITRADER66 6.7L Power Stroke Diesel 58 06-19-2014 12:09 PM
WHAT IS YOUR STRATEGY CODE AFTER NOVEMBER 09 FLASH? MoyockPowerstroke 6.0L Power Stroke Diesel 33 01-12-2010 07:10 PM
New reflash for all 6.4L Jakeman68 6.4L Power Stroke Diesel 30 10-22-2008 01:41 PM
Tags
11b23, 2009, 64, control, customer, duty, ford, module, pcm, powertrain, progam, program, recalibration, recall, satisfaction, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
