New PCM Recal. 11B23 - Page 5 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #61
Old 03-13-2011, 10:23 PM
smotrs's Avatar
smotrs smotrs is offline
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by caprang View Post
ISnt it bad to shut the engine off when the egt's are real high from a recent regen? I always let mine idle a few minutes to cool down with or without a recent regen.
Quote:
Originally Posted by senix View Post
By the time I pull in the driveway I am at idle anyway. So I put mine in park and let it run a minute or so to cool down the exhaust a little and make sure all that fuel isn't just sitting in the cylinders.
Yes, when the EGT's are high regardless of regen you should let the engine cool down. The turbos generate allot of heat and when your really pushing the engine due to driving it hard or heavy towing these temperatures climb. By letting it idle of a period of time, it gives the turbos a chance to cool down and pump cooler coolant, oil/water depending on the cooling method, through the turbo.
I do the same as senix. When you put it in park, you basically turned off the regen function. This stops the truck from pumping excess fuel into the cylinders needed for the regen. By letting it cool down for a few minutes, your giving the truck plenty of time to burn off the excess fuel so it doesn't get left behind in the cylinders resulting in the fuel washing the cylinders and ending up in the oil pan when the engine cools down.
  #62
Old 03-14-2011, 10:22 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
anyone that has the new flash have a friend with a Spartan dashdaq that can connect and get the engine and tranny 'strategy' codes. Then Spartan can support their mods on this flash level.
Sam
  #63
Old 03-17-2011, 12:10 PM
dave_1234 dave_1234 is offline
dave_1234 is starting off with a positive reputation.
Did anyone confirm that the "cleaning exhaust" messagge stays on during the regen?
I really miss that message...
  #64
Old 03-17-2011, 12:34 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
nope will not stay on with the lastest flash.
  #65
Old 03-17-2011, 02:50 PM
smotrs's Avatar
Ditto, doesn't stay on, heard the same thing from various other users.
  #66
Old 03-17-2011, 09:51 PM
RuralSurvivalGuide's Avatar
RuralSurvivalGuide RuralSurvivalGuide is offline
RuralSurvivalGuide is starting off with a positive reputation.
Drove about 300 mi. with the new flash today. Went down the hill to get my boat, so 1/2 was towing it (140 miles or so up hill 100ft to 4300ft elevation) from Redding over Eskimo Summit then down towards Reno. Had one regen as usual for 22 minutes, message came on for about 3 seconds. Don't need the message anyway, I have an Insight that lets me know. Can tell when it is through when th EGT's come down anyway. No drivability problems, loss of power, smoke, gremlins in the turbo ect.
The only difference from before the new flash is the loss of the message...big deal, especially if the new flash saves my engine some day.
I don't know for sure yet but the LOM had me at 14 mpg. I usually get 12 pulling that hill with the boat. Will see when I take out a loan to fill it up and hand calc. Wishful thinking probably.
  #67
Old 03-18-2011, 10:40 AM
abnrngr1986's Avatar
abnrngr1986 abnrngr1986 is offline
abnrngr1986 is starting off with a positive reputation.
i believe in the past when the pcm was reset or reprogramed it initially showed a little bump in mpg which eventually went back to where it was prior?
  #68
Old 03-18-2011, 01:01 PM
koboss1's Avatar
koboss1 koboss1 is offline
koboss1 is starting off with a positive reputation.
got mine done this week they gave me a sheet of what its for and said the trans is in a re-learn process for a few days
  #69
Old 03-19-2011, 12:30 AM
smotrs's Avatar
Quote:
Anything other then what's talked about so far shown on that sheet? If so, can ya scan and post?
  #70
Old 03-19-2011, 06:03 AM
senix's Avatar
I am not going to get this flash unless it becomes a recall. I can monitor everything and I want to keep my cleaning exhaust message.
So unless there is some real compeling reason.
  #71
Old 03-19-2011, 06:31 AM
koboss1's Avatar
I'm not a paid member so I can't post it. But it says that the pcm update will put the truck into limp mode or reduced power if the following are found. Water in fuel,turbo overboost, oil cooler efficiency detection,overfilled crankcase, eng coolant temp, and the wrench will show. And that the trans could be in re-learn mode for upto 7 days customer satisfaction program 11B23
  #72
Old 03-19-2011, 06:50 AM
sdetweil's Avatar
I'm not a paid member so I can't post it. ...
you can, just takes a few more steps.. once scanned, upload to photobucket, then link to it from there..
Sam
  #73
Old 03-19-2011, 11:14 AM
2010F350 2010F350 is offline
2010F350 is starting off with a positive reputation.
I had mine done the other day, and the only thing I noticed that was different was the LOM showing my fuel millage being better.
  #74
Old 03-19-2011, 05:33 PM
RoadJunkie RoadJunkie is offline
RoadJunkie is starting off with a positive reputation.
Got my letter today, no I have to decide whether or not to have the reflash. I'm struggling with the "If it ain't broke, don't fix it". But I think a reflash is inevitable at some point, so maybe I should just get it over with.
  #75
Old 03-19-2011, 05:49 PM
judithgap's Avatar
judithgap judithgap is offline
judithgap is starting off with a positive reputation.
Received mine today. Guess I will have it done at my next service.
how to test - 11B23 calibration update - oil over filled speakerfritz 6.4L Power Stroke Diesel 0 08-03-2016 01:05 PM
Would dealer update latest PCM strategy on engine pull? diesel_dan 6.0L Power Stroke Diesel 11 04-26-2016 10:21 AM
Customer Satisfaction program 12B33 OPTITRADER66 6.7L Power Stroke Diesel 58 06-19-2014 12:09 PM
WHAT IS YOUR STRATEGY CODE AFTER NOVEMBER 09 FLASH? MoyockPowerstroke 6.0L Power Stroke Diesel 33 01-12-2010 07:10 PM
New reflash for all 6.4L Jakeman68 6.4L Power Stroke Diesel 30 10-22-2008 01:41 PM
Tags
11b23, 2009, 64, control, customer, duty, ford, module, pcm, powertrain, progam, program, recalibration, recall, satisfaction, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
