New PCM Recal. 11B23 - Page 4 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #46
Old 03-10-2011, 05:34 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
I drove a truck the other day and the message center was lit up with cleaning filter message.
  #47
Old 03-10-2011, 06:47 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
that is good news as that is the only way I would do this update myself. Especially considering mine runs perfect the way it is.
Still thinking I might just pass it up.
  #48
Old 03-10-2011, 06:57 PM
jimd1050's Avatar
jimd1050 jimd1050 is offline
Worry later? IT IS LATER!
jimd1050 has a very good reputation on FTE.jimd1050 has a very good reputation on FTE.jimd1050 has a very good reputation on FTE.
Timing SUCKS!
I'm really gonna test this new flash - I was 1/2 mile from work this morning and it went into Regen. I have to work - I'm not driving another 14 miles or so because the truck needs a Regen! I left work tonight expecting the thing to go into Regen to re-start the canceled morning Regen. Nothing for the entire 40 mile commute... I put my right directional on to turn into my driveway at 6:00 PM and... Yep, you guessed it, "Cleaning F'n Exhaust Filter"! I stormed up the driveway and shut the S.O.B. OFF!
Let's see what happens in the morning when I remote start it and let it idle for 15 or 20 minutes in the driveway warming up? If I get a Wrench Error or go into Limp Mode, I'm going to drive it through the front window of my Dealership... watch the National News tomorrow night. "Massachusetts Man goes Berzerk at local Ford Dealer!"
That would be me!
  #49
Old 03-10-2011, 07:23 PM
senix's Avatar
Jim,
That is exactly what I would of done! Bet you get the mandatory drive to clean message next...but hopefully it comes on as soon as you hit about 150 deg.
  #50
Old 03-10-2011, 07:56 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
That would be me!
It'd take a lot more than that to plug your DPF.
My truck has a similar DPF system to what's on the 6.4L engine, and I never worry much about it. I've shut it off numerous times just after regen with no issues, it really takes a lot to plug these units as long as everything is running right.
Relax and drive the truck, it'll be fine.
  #51
Old 03-10-2011, 08:32 PM
caprang's Avatar
caprang caprang is offline
caprang is gaining momentum as a positive member of FTE.
ISnt it bad to shut the engine off when the egt's are real high from a recent regen? I always let mine idle a few minutes to cool down with or without a recent regen.
  #52
Old 03-10-2011, 09:08 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
I just drive mine, and ignore the regen. That's why the 'drive to clean exhaust filter' message.
The engineers had to know this stuff would happen, and you can't kill the truck for one stop.
Sam
  #53
Old 03-11-2011, 05:13 AM
senix's Avatar
Quote:
By the time I pull in the driveway I am at idle anyway. So I put mine in park and let it run a minute or so to cool down the exhaust a little and make sure all that fuel isn't just sitting in the cylinders.
  #54
Old 03-11-2011, 06:25 AM
jimd1050's Avatar
Completed this morning...
Warmed up in the driveway for about 20 minutes this morning - at three miles after leaving the house, it went into Regen. Regen completed at approximately 15 miles - damned, I was so looking forward to being on the NEWS tonight!
  #55
Old 03-11-2011, 06:35 AM
senix's Avatar
Well when you get that 6-gun it will help to extend those intervals...
  #56
Old 03-11-2011, 02:14 PM
Eric326 Eric326 is offline
Eric326 is starting off with a positive reputation.
Did you "cleaning exhaust" message stay lit the entire time?
  #57
Old 03-11-2011, 04:18 PM
jimnv's Avatar
jimnv jimnv is offline
jimnv is starting off with a positive reputation.
Took my 08 in for a fuel filter replacement just today
Service manager said "...and oh by the way, we initiated a recall that was put out last week or so". He explained to me what it did and why. I expect its going to be something the dealership is "mandated" to do whether we wanted it or not.
I'm still at work so I am going to be watching the dash very carefully plus the performance.
  #58
Old 03-11-2011, 07:25 PM
Gearitis Gearitis is offline
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
Yep! Took mine in today for a check on the black pipes (did a 900 mile tow with my 5er and came back with more black than I had ever seen) and the service manager said "that while its in here" we are required to do the "new pcm adjustment". My question was, "what is the positives and negatives"? His answer was that I would get better warning of malfunctions and longer intervals between regens, better notification of regen process. The only downside that he was informed was the time it took to do the flash. My other question was "can we go back to the former pcm revision, that is in case it does not perform as well as it does now. He said it is not a good idea to go back but can be done.
I guess we will see.
  #59
Old 03-11-2011, 07:28 PM
senix's Avatar
How far apart we your regens?
  #60
Old 03-12-2011, 07:47 AM
Quote:
90-100 miles and not more. With regens that close together, still averaged 10.4 mpg. Headwind of 30 coming back, impressed the milage was not worse. Will post back with the results on Tuesday or so.
how to test - 11B23 calibration update - oil over filled speakerfritz 6.4L Power Stroke Diesel 0 08-03-2016 01:05 PM
Would dealer update latest PCM strategy on engine pull? diesel_dan 6.0L Power Stroke Diesel 11 04-26-2016 10:21 AM
Securilock-DELETE? freeranger 2015+ F150 14 06-09-2015 09:31 PM
Customer Satisfaction program 12B33 OPTITRADER66 6.7L Power Stroke Diesel 58 06-19-2014 12:09 PM
Explorer Shop Manual PupnDuck 2011 & Newer Explorer 1 12-15-2013 09:34 AM
Tags
11b23, 2009, 64, control, customer, duty, ford, module, pcm, powertrain, progam, program, recalibration, recall, satisfaction, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
