New PCM Recal. 11B23 - Page 10 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #136
Old 03-28-2011, 01:35 PM
smartken22's Avatar
smartken22 smartken22 is offline
smartken22 is starting off with a positive reputation.
Quote:
Originally Posted by senix View Post
Did you unhook the 6-gun or just did the setting at stock on the IQ?
I put the IQ to stock and then unplugged from the OBDII port. I left everything else installed.
  #137
Old 03-28-2011, 01:50 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
That was what I was planning on doing as well. No need for them to be under the hood for this one.
  #138
senix's Avatar
  #139
Old 03-28-2011, 02:32 PM
smartken22's Avatar
Agreed. It was a very quick process. They just hooked up and the job was completed in about 20min. They never opened my hood. Once I got home, I reconnected the OBDII for the IQ and everything seems good so far. I am still running stock right now until the tranny re-learns and then I will go back to setting 3. I might do that on the way home today.
  #140
Old 03-28-2011, 02:52 PM
richfaa richfaa is offline
richfaa is starting off with a positive reputation.
had it done notice no difference what so ever.
  #141
Old 03-28-2011, 05:22 PM
RoadJunkie RoadJunkie is offline
RoadJunkie is starting off with a positive reputation.
I called my dealer to schedule an appointment for the PCM flash (11b23) and they were very concerned because the expiration date for the bulletin is Thursday, the 31st. Wow, I sure am confident of this place!
  #142
Old 03-28-2011, 05:24 PM
jrtraderny jrtraderny is offline
jrtraderny is gaining momentum as a positive member of FTE.
Well, just left my dealer and they recommended not to do it yet. Service advisor said there have been complaints of poor fuel mileage. (like it's not bad enough already).
And some tech's claim they've let the smoke out of the pcm.
jr
  #143
Old 03-28-2011, 05:25 PM
Quote:
That would be in 2012 ha ha.
jr
  #144
Old 03-28-2011, 09:17 PM
sdrono's Avatar
sdrono sdrono is offline
sdrono is starting off with a positive reputation.
Took mine in today and it was done in less than 20 min. My Tech guys said that I would notice some power gain. Drove truck around about 20 miles mostly on 55-60 mph roads. What I noticed was that the boost didn't seem as high and I went from 12.8 on LOM to 15.9. I will e driving truck more this week so will fill up and start from fresh tank. It seemed like I had a little more punch also, but I usually keep the boost below 20 when driving. Might add that my hand calcs and LOM are within .5 mpg of each other.
  #145
Old 03-29-2011, 11:23 AM
DynamoDale's Avatar
DynamoDale DynamoDale is offline
DynamoDale is starting off with a positive reputation.
My appointment is tomorrow and the service adviser told me it will take 1hr-1 1/2hrs for the job. WTH they going to put a new motor in or what? LOL I hope it only takes 20 mins.
  #146
Old 03-29-2011, 12:05 PM
sideshow's Avatar
sideshow sideshow is offline
sideshow is gaining momentum as a positive member of FTE.sideshow is gaining momentum as a positive member of FTE.
I had mine done last week, and the lie-o-meter on my truck has shown a 2-3 mpg increase. I'm not claiming it's accurate (although my hand calculations show it fairly close) just stating that all things being equal, and with no driving style changes, the LOM went from hovering around 14 mixed driving to about 17. driven a few hundred miles since then, and it does seem smoother and peppier. may be power of suggestion, but it does seem to have a little more pep. I haven't hand calculated the last two tanks of fuel, since the pumps cut me off at 75 bucks, and I've been in too much of a hurry to re-run the card and top off. Not expecting any significant increase, but anything no matter how marginal would be more than welcomed. Gotta save some duckets for the spartan or black maxx and dpf/doc delete.
  #147
Old 03-29-2011, 06:34 PM
catd9n1 catd9n1 is offline
catd9n1 is starting off with a positive reputation.
Recall????
Called to have an appointment on Friday, dealer called Thursday and said Ford told them to cancel appointment for two weeks. They were having issues with the recall! Has anyone had this happen!?!?!!?
  #148
Old 03-29-2011, 07:18 PM
Quote:
My dealer wouldn't do mine yesterday, said he'd been reading bad stuff on the dealer message board.
jr
  #149
Old 03-29-2011, 08:14 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
I know someone here has access to the IDS system... could you check the strategy codes for the engine/tranny for this update.. it appears the install didn't take on my truck, cause my strategy codes didn't change.
Sam
  #150
Old 03-29-2011, 08:22 PM
senix's Avatar
interesting...I knew there was a reason for not being in a hurry for this update.
how to test - 11B23 calibration update - oil over filled speakerfritz 6.4L Power Stroke Diesel 0 08-03-2016 02:05 PM
Would dealer update latest PCM strategy on engine pull? diesel_dan 6.0L Power Stroke Diesel 11 04-26-2016 11:21 AM
Explorer Shop Manual PupnDuck 2011 & Newer Explorer 1 12-15-2013 10:34 AM
WHAT IS YOUR STRATEGY CODE AFTER NOVEMBER 09 FLASH? MoyockPowerstroke 6.0L Power Stroke Diesel 33 01-12-2010 08:10 PM
New reflash for all 6.4L Jakeman68 6.4L Power Stroke Diesel 30 10-22-2008 02:41 PM
Tags
11b23, 2009, 64, control, customer, duty, ford, module, pcm, powertrain, progam, program, recalibration, recall, satisfaction, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
