'03 v10 y-pipe, good or bad??? - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 03-07-2011, 12:10 AM
nunomad nunomad is offline
nunomad is starting off with a positive reputation.
I've got an '03 excursion with a V10 in it, I am quite happy with performance of the engine but don't know any different. Does the 03 breath better with different Y-pipe install, or is it the better of the factory installed pipes.If I should change it out, any recommendations on which of the aftermarket are better for performance and mileage.Any advice is greatly appreciated. Nunomad
Old 03-07-2011, 08:45 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
All you have to do is look at it - if each primary pipe is necked-down for about 2 inches just before they join up, that pipe SUCKS.
And, chances are, you DO have the necked down y-pipe.
When I replaced mine with an eBay y-pipe given to me by another member, it greatly improved low-RPM throttle response. It didn't do anything else, but did make the truck more enjoyable to drive around-town.
Old 03-07-2011, 02:11 PM
LSchicago2's Avatar
LSchicago2 LSchicago2 is offline
LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.
If you have a 2 valve, you have the restrictive pipe. I replaced mine on the 03 I had, and it was much better on fuel.
Old 03-07-2011, 02:45 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Do you need to remove the exhaust manifold to upgrade the y-pipe? I don't want to mess with those studs if I don't have to.
Old 03-07-2011, 08:37 PM
KOESTNER's Avatar
KOESTNER KOESTNER is offline
Illinois Chapter LDR
KOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputation
I replaced the necked down Y pipe with the stainless Y from SPD, two years ago and couldn't be happier with the performance, less a tune from 5 Star. There wasn't much noticeable gain in MPG but the performance gain was well worth it. No need to remove the exhaust manifold to install but loosening the stock Y from the left manifold after cutting helps in installation BSEG.
Old 03-08-2011, 08:47 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
No.
Only downside to replacing the stock y-pipe with an SPD (or similar) is you will get flutter if you have the stock exhaust manifolds.
Old 03-11-2011, 06:59 PM
krusterzf-350's Avatar
krusterzf-350 krusterzf-350 is offline
krusterzf-350 is starting off with a positive reputation.
Quote:
Originally Posted by dkf View Post
No.
Thats true! I replaced mine with the spd y-pipe, and now have a LOT of flutter. Oh well. Maybe time for some ebay headers?
Old 10-29-2012, 09:39 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Yes old thread, but I'm using the "search" feature, looking at buying a excursion, and first thing is the y pipe, what do u guys mean by flutter??
Old 10-30-2012, 11:18 AM
bakon bakon is offline
bakon is gaining momentum as a positive member of FTE.bakon is gaining momentum as a positive member of FTE.
I put hedman y pipe and headers. See thread for info. Would recommend changing out stock and if you are blowing studs, should pull trigger and do them too if you are keeping truck.
Old 11-01-2012, 03:48 PM
WestxSRT10's Avatar
WestxSRT10 WestxSRT10 is offline
WestxSRT10 is starting off with a positive reputation.
Quote:
"flutter" The noise comes from the exhaust pipe outlet,this happens mostly while changing gears/shifting under hard accelleration. Sounds like a loose flap of metal vibrating deep inside the pipe.
Old 11-02-2012, 12:22 AM
KOESTNER's Avatar
Quote:
Originally Posted by WestxSRT10 View Post
The noise comes from the exhaust pipe mostly while changing gears/shifting. Sounds like a loose flap of metal vibrating inside the pipe.
Check the torque converter inspection cover. They sometimes rattle between 1700 and 2200 RPM. Remove it and go for a ride. If the noise is gone, bend it a bit and reinstall it.
Old 11-30-2012, 03:16 PM
TX03EX's Avatar
TX03EX TX03EX is offline
TX03EX is starting off with a positive reputation.
How loud is the Flutter. id hate to spend a hunsky and instalation only to be annoyed by exhaust noise. id rather not hear anything as the v10 doesnt sound too good. with my Flowmaster 70bb it sounds awesome at idle and when my wife drives off in it its not loud outside, but its loud inside the x while driving
Old 11-30-2012, 07:44 PM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
Quote:
The flutter is very loud and annoying that is one reason I have never changed anything from the engine to the cat.
Denny
Old 11-30-2012, 10:56 PM
hav24wheel's Avatar
Well hopefully it's not horrible. I got a eBay y pipe coming n a 4 inch deisel exhaust coming.
Old 12-03-2012, 05:08 PM
captchas captchas is offline
Guest
captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.
No.
yes your correct and that flutter noise will drive you crazy after a while.
Installed new Y-pipe. Impressed with results flybaby_3 Modular V10 (6.8l) 71 11-05-2016 01:15 PM
Modified factory v10 y-pipe sandman3510 Ford Truck Parts for Sale 4 09-10-2016 10:13 AM
Factory y-pipe kenneBF250V10 Modular V10 (6.8l) 8 03-31-2015 02:58 PM
y-pipe for true duals on 92 f150 4x4 5.0? Anthonynoble 1987 - 1996 F150 & Larger F-Series Trucks 22 03-09-2015 11:07 PM
'03 Ex headlight upgrade?? nunomad Excursion - King of SUVs 15 11-30-2010 08:59 PM
Tags
2003, bad, cross, duty, eccursion, excursion, exhuast, f250, ford, good, pipe, pipes, super, tuner, v10, ypipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
