'03 v10 y-pipe, good or bad??? - Page 2 - Ford Truck Enthusiasts Forums
Old 03-11-2014, 11:25 PM
chefcollins1 chefcollins1 is offline
chefcollins1 is starting off with a positive reputation.
Koestner:
When you remove the torque converter inspection cover, do you have to deal with transmission fluid spilling out the cavity? I have the rattle in 2nd gear at 1900 RPM and it really sounds like metal rattling more than anything else. Thank you.
Jason
Old 03-11-2014, 11:37 PM
KOESTNER's Avatar
KOESTNER KOESTNER is offline
Illinois Chapter LDR
KOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputation
Quote:
Originally Posted by chefcollins1 View Post
Koestner:
Jason
The bell housing is not sealed, nothing leaks out. That cover is causing the noise that you hear. Bend it some and reinstall it.
Your welcome Jason.
Old 03-12-2014, 10:23 AM
fordboy2's Avatar
fordboy2 fordboy2 is online now
fordboy2 is gaining momentum as a positive member of FTE.
does anyone have a video of what the flutter sounds like? I want to see if I change my y pipe if I can tolerate the noise.
Old 03-12-2014, 10:05 PM
WE3ZS's Avatar
WE3ZS WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
Quote:
Your signature shows a deezle, so the Y pipe and flutter are non issues for that. If this is for another rig with the V-10 then carry on, I don't have any flutter vid links but search around on Youtube for some.
Old 03-12-2014, 10:25 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
I never got any flutter, just drone....
Old 03-13-2014, 09:05 AM
fordboy2's Avatar
Yea I need to update my sig I now have two v10s a 99 and a 02.
Old 03-13-2014, 10:03 AM
ForKyleigh ForKyleigh is offline
ForKyleigh is starting off with a positive reputation.
I must say I find it very ironic that there are 0 sound clips of an exhaust with the ypipe and yet everyone says how terrible it sounds.
Someone prove the point please! Attached a before and after!
Old 03-13-2014, 01:22 PM
hav24wheel's Avatar
I have clips of mine with the y pipe in my Photobucket, but you won't find flutter in it.
Old 03-13-2014, 11:04 PM
KOESTNER's Avatar
No drone or flutter with mine.
Old 03-13-2014, 11:10 PM
meanv10's Avatar
meanv10 meanv10 is offline
meanv10 is starting off with a positive reputation.
no mater how much you mod a v10 u will never feel a difference in power unless u do gears, nitrous or super/turbocharger...... so save your money
also no mater how hard you try you will never get 12mpg lol
Old 08-08-2014, 04:44 PM
eternal_177 eternal_177 is offline
eternal_177 is gaining momentum as a positive member of FTE.eternal_177 is gaining momentum as a positive member of FTE.
04 Excursion Mods
I did the 03 3valve y pipe, K&N filter, Autozone throttle body spacer, remove the cat and added a 3" dynamax muffler and a Superchip programmer. I also put 285/75/16 mud tires on it. I drive it every day and in 87 octane economy I was getting 9mpg to 9.6, but... when I switch it to the performance tune STILL WITH 87 OCTANE! @ 70 on the freeway and this is no bull the ceiling screen said anywhere from 12mpg deep in the trottle to 15 MPG!!!!! I drove it 190 miles that day. In the city I'm averaging 9mpg to 10.5mpg depending on my foot. Lol NO DRONE OR FLUTTER! 373 gears!!!
Old 08-08-2014, 07:31 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
If you got the SPD ypipe or similar y-pipe with the stock manifolds you have flutter plain and simple. If you say you don't it is obvious you don't know what flutter is and what it sounds like. Probably because you havn't worked on V10 trucks enough with enough exhaust manifold, header and exhaust combinations to know the difference.
The stock manifolds are the cause of flutter on the 99'-04' V10s. The later 00'-04' y-pipe is necked down to get rid of the flutter, which it does quite well. Guess why the 3V 6.8l does not have flutter issues, it uses a much better manifold design with longer primaries.
If I could take you for a ride in my dads V10 with stock manifolds, SPD and Force II exhaust and then take you in my V10 with Thorleys and Force II exhaust you would hear the difference instantly. I could throw 2 more mufflers on my dads truck and you could still hear the flutter in the cab and out the tailpipe at certain rpms. Loud exhaust makes it harder to hear flutter inside the truck but makes it more apparent outside the truck.
Monsta did a video showing flutter years ago that came out pretty good. But it can be hard to get on video sometimes.
  #28
Old 08-09-2014, 06:36 PM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith XL1200LTD-Keith is offline
XL1200LTD-Keith is starting off with a positive reputation.
Monsta's Flutter Video
This is a link to Monsta's flutter video.
2005 Ford Excursion My 05 video | SuperMotors.net
I think he used the Flowmaster Y-pipe.
http://www.ford-trucks.com/user_gall...102459&width=2
  #29
Old 08-10-2014, 11:23 AM
I watched the video and mine doesn't sound like that. I will try to do a vid today. Like said earlier I used the stock 03 3 valve y pipe.
  #30
Old 08-10-2014, 07:31 PM
dkf's Avatar
dkf dkf is offline
There was no 3V in 2003. The 3V did not come out until 2005 in the SD. Plus the y-pipe, converter portions, exhaust manifolds and etc on the 3V are different than the 2V trucks. If you have the stock ypipe that came on a 2003 V10 SD that is designed to reduce or eliminate exhaust flutter. The 1999- early 2000 y-pipes were a different design and had flutter.
Installed new Y-pipe. Impressed with results flybaby_3 Modular V10 (6.8l) 71 11-05-2016 01:15 PM
Modified factory v10 y-pipe sandman3510 Ford Truck Parts for Sale 4 09-10-2016 10:13 AM
Factory y-pipe kenneBF250V10 Modular V10 (6.8l) 8 03-31-2015 02:58 PM
y-pipe for true duals on 92 f150 4x4 5.0? Anthonynoble 1987 - 1996 F150 & Larger F-Series Trucks 22 03-09-2015 11:07 PM
'03 Ex headlight upgrade?? nunomad Excursion - King of SUVs 15 11-30-2010 08:59 PM
Tags
2003, bad, cross, duty, eccursion, excursion, exhuast, f250, ford, good, pipe, pipes, super, tuner, v10, ypipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
