2004 SuperCab Rear door panel removal.... - Ford Truck Enthusiasts Forums
Old 03-06-2011, 11:31 PM
motolorenzo's Avatar
motolorenzo motolorenzo is offline
motolorenzo is starting off with a positive reputation.
Has anyone seen instructions or can tell me the trick to remove the rear (L) door panel on the 2004 Super Cab door. Only one visable screw on the very bottom of the panel. I have a new window (glass) I want to install. Any info appriciated. Renzo in Kau, Hawaii
Last edited by motolorenzo; 03-07-2011 at 06:42 AM. Reason: I posted Screw rather than Scab
Old 03-07-2011, 08:14 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
Just did this last week. Well there are several more screws that are hidden. First carefully pry off the top 2 pieces on either side of the glass. Remove the 2 screws there. Next, pry up on the window switch panel and unplug the power window switch. There is a screw under that. Remove the cover panel on the door latch. Remove the 2 screws that hold the handle on. Now you should be able to lift the panel straight UP do not try and pull out you'll break off the tabs. Reinstalling the door handle is the toughest part. You sorta have to get it in the right place. Took me a couple trys but I got it.
Old 03-07-2011, 08:58 PM
dgndngrngr84's Avatar
dgndngrngr84 dgndngrngr84 is offline
dgndngrngr84 is starting off with a positive reputation.
Item Part Number Description
1 1625514/ 1625515 Rear window garnish moulding (RH/LH)
2 W701930-S424 Bolts (3 required)
3 14B134/ 14B135 Rear window control switch panel (RH/LH)
4 14635 Electrical connector
5 W505424-S301 Door handle bezel bolt
6 224A60 Rear door handle cover plate
7 W701704-S309 Rear door handle bolts (2 required)
8 264B52/ 264B53 Rear door handle (RH/LH)
9 1827406/ 1827407 Rear door trim panel (RH/LH)
Old 03-08-2011, 12:57 AM
Door Panel Removal & window replacement!!!
Pulled the Panel and replaced the window!!! No fun for a non glass shop Guy but I "Got er done" You have to pull all the mouldings, inside and outside, then install the window from the top, inside. I looked everywhere I could think of for some expert advice but didn't find anything. Lots of DIY instructions on the door panel and replacing the electric window motor and drive, but NOTHING on window replacement! Renzo in Kau, Hi.
removing front door panels 2004 explorer turborich Explorer, Sport Trac, Mountaineer & Aviator 4 12-09-2011 10:31 AM
door panel removal billy13 Expedition & Navigator 2 12-14-2009 11:29 AM
Door Panel Removal Bluze 1987 - 1996 F150 & Larger F-Series Trucks 11 02-06-2009 02:47 PM
'05 F250 SD XL rear door panel removal? fairlaniac 1999 to 2016 Super Duty 4 07-03-2008 03:04 PM
SD SC Rear Door Panel Removal wolfmanagh 1999 to 2016 Super Duty 2 10-14-2002 12:09 PM
Tags
2004, 2009, cab, door, f150, f250, ford, panel, power, rear, removal, remove, super, supercab, supercrew, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
