1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Keyless Entry Code Location
Old 03-06-2011, 08:28 PM
Airborne Cajun's Avatar
Airborne Cajun
Airborne Cajun is offline
Unhappy Keyless Entry Code Location
I have a 2005 F-550 Super Duty Crew/cab Dualley with the 6.0 Turbo Diesel.
Where can I find the the PCM computer inside the cab that would have the factory key-less entry code stamped on it?
I purchased this truck in Oct. used ,and the card in the owners wallet that would have the factory code is long gone. HELPPPP.....
Darryll
Old 03-06-2011, 08:47 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Old 03-06-2011, 09:06 PM
Airborne Cajun
Thank-you Very Much.....
Old 03-06-2011, 09:18 PM
powerstroke72
Yes sir, you're welcome.
Old 03-17-2011, 10:00 PM
BlackNM6.0's Avatar
BlackNM6.0
BlackNM6.0 is offline
powerstroke72,
I'd like to thank you also. That first thread you listed was exactly where mine is located and the pictures are worth a thousand words, or more. I spent two hours ripping apart my dash and still could not find the code. I did manage to lose a mounting screw from the radio tho, so I've got that going for me. Wish I had found this thread sooner. Thanks again.
This is why I love forums. So many knowledgeable people.
Old 03-17-2011, 10:15 PM
powerstroke72
My pleasure my friend and welcome to FTE!
I wish I could take credit for those great threads but I'm merely a conduit for the information. I had my dash apart last year to install my SIRIUS radio and saw my code while I was in there.
I'm with you on the forums. This site has been great to me over the years and there are a lot of very knowledgeable folks here.
Glad to have you all on board.....hang around with us and post up your questions and solutions. We're always looking for more good tips.
Also when you get a chance, drop in and check out the Tech Folder at the top of the forum...if you haven't already.
Old 09-06-2011, 06:43 PM
Special Ed's Avatar
Special Ed
Special Ed is offline
Thank you Powerstroke! Found factory code & have personal entry code now programmed. This site rocks!
Old 09-09-2011, 01:07 AM
Dbergeson's Avatar
Dbergeson
Dbergeson is offline
YES!
Thanks from another user, I searched and searched. BLAM thread and a little twisting and lots of moving and yanking the batting out. And I got myself a code.
Cheers!
Old 09-09-2011, 01:11 AM
powerstroke72
Superb! Glad you folks are having success finding these codes.
Old 09-09-2011, 01:31 AM
mountie's Avatar
mountie
mountie is offline
I pulled the dash to pieces on my 07. Never did find it. Had to go to the dealer. I think he felt bad for me and did it for nothing.
Old 04-22-2019, 04:19 PM
mjsallie's Avatar
mjsallie
mjsallie is offline
Lightbulb Keyless entry code is in fuse panel
Th Keyless entry code is in the fuse panel of my 2015 F250
Old 04-25-2019, 09:18 PM
FunkMonkeyTX's Avatar
FunkMonkeyTX
FunkMonkeyTX is offline
If you have more than one key there may be a routine to have the code displayed on the dash. Not sure about older models, but I’ve done it successfully on a 2014 F250 and a 2014 Fusion
Old 04-27-2019, 08:04 AM
96_F250_Deezal's Avatar
96_F250_Deezal
96_F250_Deezal is offline
On 2011-2016 superduties the keysless codes is usually on a stick on the BCM cover.
However you can almost always retrieve the code using FORScan. Do this by going to service procedures and look for the option to "read factory keyless entry code". In the example provided, the code is in the drivers door module and since this particular car doesnt have keyless entry, it reads the code as 1 1 1 1 1. I would expect the code to be in the BCM for most other Ford models.
Pdaw1541
2017+ Super Duty
12-17-2017 08:39 PM
crozz
2004 - 2008 F150
09-26-2016 08:16 AM
cassenbl
04-07-2015 12:33 PM
trpr322
12-10-2010 10:41 PM
logginhard
05-15-2004 11:23 PM
Quick Reply: Keyless Entry Code Location
