Keyless Entry Code Location
I have a 2005 F-550 Super Duty Crew/cab Dualley with the 6.0 Turbo Diesel.
Where can I find the the PCM computer inside the cab that would have the factory key-less entry code stamped on it?
I purchased this truck in Oct. used ,and the card in the owners wallet that would have the factory code is long gone. HELPPPP.....
Darryll
Darryll
Try this thread:
Ford Truck Enthusiasts Forums - View Single Post - Is there a way to get the keyless entry code without going to the dealer?
This one may help also:
https://www.ford-trucks.com/forums/s...82&postcount=9
And, Welcome to FTE!
Try this thread:
Ford Truck Enthusiasts Forums - View Single Post - Keyless Keypad Code
I'd like to thank you also. That first thread you listed was exactly where mine is located and the pictures are worth a thousand words, or more. I spent two hours ripping apart my dash and still could not find the code. I did manage to lose a mounting screw from the radio tho, so I've got that going for me. Wish I had found this thread sooner. Thanks again.
This is why I love forums. So many knowledgeable people.
My pleasure my friend and welcome to FTE!
I wish I could take credit for those great threads but I'm merely a conduit for the information. I had my dash apart last year to install my SIRIUS radio and saw my code while I was in there.
I'm with you on the forums. This site has been great to me over the years and there are a lot of very knowledgeable folks here.
Glad to have you all on board.....hang around with us and post up your questions and solutions. We're always looking for more good tips.
Also when you get a chance, drop in and check out the Tech Folder at the top of the forum...if you haven't already.
On 2011-2016 superduties the keysless codes is usually on a stick on the BCM cover.
However you can almost always retrieve the code using FORScan. Do this by going to service procedures and look for the option to "read factory keyless entry code". In the example provided, the code is in the drivers door module and since this particular car doesnt have keyless entry, it reads the code as 1 1 1 1 1. I would expect the code to be in the BCM for most other Ford models.
logginhard
05-15-2004 11:23 PM
