Best plugs for 4.9L ?? Timing ? - Ford Truck Enthusiasts Forums
Old 03-06-2011, 05:52 PM
njneer1's Avatar
njneer1 njneer1 is offline
njneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to all
Ok.....long time since I dealt with a 300........best plugs still Autolite?? where is everyone running the timing at ??.....mines an 1988.....what is the best you guys recommend ?
Old 03-06-2011, 09:29 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
I'm running Autolite 45s and 13BTDC with good results on high compression. My old 300 ran very well at 18BTDC. For these old engines, the best way to time them is to turn it to where it runs best, then back off till it stops pinging. An EGR might change the way you have to time it, but you can be a little more aggressive with that.
Old 03-06-2011, 10:33 PM
njneer1's Avatar
Thanks man.....any idea what your total timing is ?? is it 35 degrees more or less ??
Old 03-06-2011, 11:11 PM
coffeetwitch666 coffeetwitch666 is offline
coffeetwitch666 is starting off with a positive reputation.
88? isnt that efi? they like the timing at 10* btdc base.
Old 03-07-2011, 04:55 PM
njneer1's Avatar
Quote:
Thanks ...Yes EFI.......is there a connector that needs pulled to set base timing ??? if so where is it ??
Old 03-07-2011, 05:51 PM
As you looking at your distributor, there is a plug for your tfi (ignition control) in that same loom/bundel there it is. Could also be wraped in tape but its there. It should be the only thing that looks like it doesnt have a place to go.
Old 03-07-2011, 09:41 PM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
My old 94 liked 12 deg BTDC with Motorcraft copper core plugs gapped at .050. It had a good quality Taylor low resistance sprial wire set with OEM type (brass contacts) cap and rotor. Truck was a sb reg cab and weighed about 4000lb. It had 3.55 gears and 235/15/75 tires. The timing and wire change increased acceleration slightly and the truck was capable of delivering 20 mpg at 60 mph.
My 95 is an extended cab with a sb and it has 3.08 gears. I used the same formula as the 94 but i had to back off the timing to 10 BTDC. I used Autolites this time (on sale) set to the same gap. It averages about a mpg less but actually performs slightly better than the 94.
I did consider a "performance coil" but my originals always tested fine and had no trouble with the .050 gap. Some users will open the gap to .055 on the plugs but I was concerned about cold weather starts. You can adjust the timing by using a vacuum gauge and the "sixliter tune up" has been a popular mod.
Regards
rikard
Old 03-07-2011, 09:54 PM
desperado_18_2000's Avatar
desperado_18_2000 desperado_18_2000 is offline
desperado_18_2000 is gaining momentum as a positive member of FTE.
For those of us that have an old Carb'd motor I've heard rumor that its best to run EFI plugs as they reach a little longer and give a better burn. I'm going to be trying this out with my engine. I know I've read about it over at Ford Six for sure.
Old 03-07-2011, 10:23 PM
hey rikard, what is the "sixliter tune up"?
Old 03-08-2011, 10:58 AM
The "Sixliter tuneup" refers to a write up done by Sixliter for the 302 but it will work for other engines as well.
It consists of low resistance ignition wires a MSD rotor, cap, coil, and Motorcraft copper plugs.
The plug gap is set to .055 instead of .044 and timing is set at 14 BTDC instead of 10 BTDC. The low resistance wires and aftermarket coil allow the larger gap to work producing a bigger spark. Most users report better performance and gas mileage
For more details doe a search on any of the Ford sites.
regards
rikard
Old 03-08-2011, 01:45 PM
Sounds interesting. Thanks for the info. Im due for a tune up and will do a search for it.
njneer1, Hows your truck coming along?
Old 03-19-2011, 11:04 AM
njneer1's Avatar
Jumped to the rearend last weekend and did both new wheel cylinders, brake shoes.....and a set of BFG 33' AT's.......front end today and tomorrow
Does anyone have a pic of that timing connector on the 4.9L ??
Old 03-19-2011, 11:31 AM
JimsRebel's Avatar
JimsRebel JimsRebel is offline
JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.
SPOUT connector photos
SPOUT connector info
Ford Fuel Injection Setting the timing
You should be able to find a picture if you Google spout connector as there are different styles.
Jim
Melted uvch and pigtails kyle j 1994.5 - 1997 7.3L Power Stroke Diesel 3 04-13-2016 08:36 PM
Best COPS For v10? 96mark8 Modular V10 (6.8l) 12 02-18-2014 07:47 AM
Whar are Best Plug Wires? Macs1964F100 1961 - 1966 F-100 & Larger F-Series Trucks 2 02-18-2013 09:44 PM
Best Plugs & Wires for 2006 4.6? someguyarerude Explorer, Sport Trac, Mountaineer & Aviator 9 02-06-2012 08:00 PM
Best spark plug for flathead with Edelbrock Heads? 51phil 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 05-30-2011 07:31 PM
Tags
1995, 49, 49l, adjust, change, excursion, f150, f250, ford, i6, liter, plug, plugs, set, specs, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
