PATS key relearn after PCM relacement - Ford Truck Enthusiasts Forums
Old 03-06-2011, 05:25 PM
matt in AZ matt in AZ is offline
matt in AZ is starting off with a positive reputation.
Hello,
I hope you guys can offer me some advice and guidance. I have a f150 2002 5.4L. It was originally a bi fuel truck. When I bought it a few years ago the propane system did not work. I got a new system put in. ( the alt fuel place that put it in is now out of business). I have been having trouble with an O2 sensor which I could not figure out. I brought it to a Fletchers around the corner to have them take a look at it. They really screwed it up. It was undrivable in the gas mode it drove when using propane. I checked the wires and cleaned them up and bought a PCM from Checker/O'Rielly and installed it. I now get the theft light flashing and it does not start although it cranks. I'm guessing it is due to the PATS system. Does anyone know how I can get the system to recognize the keys? or am I screwed and have to bring it to a dealer?
Thank for any advice.
Matt
Old 03-06-2011, 05:46 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Tow it to a dealer.
Old 03-06-2011, 07:59 PM
thecardoc thecardoc is offline
thecardoc is starting off with a positive reputation.
Try a GOOD locksmith some have the equipment to reprogram . Also O'Rielly may have the ability to reflash your PCM alot of parts stores have this service available .
Only go to the dealer as a very last resort .
Old 03-07-2011, 09:16 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
You need a parameter reset done and as far as I know the dealer is the only place that can do it. You also need as-built data loaded into the PCM. The pats keys are stored in the cluster and the PCM and cluster have to be programmed to each other.
PATS- How will it affect my build? Psyclopse Excursion - King of SUVs 3 03-14-2016 11:29 AM
2008 F-350 need PATS light example from truck without PATS key security system larkimg 1999 to 2016 Super Duty 0 05-05-2014 01:45 PM
I need Help....... goodmatt2002 Computer Chips & Tuners 7 06-20-2012 11:34 PM
SCT tsx, pats, transmission problem HELP! goodmatt2002 Excursion - King of SUVs 1 06-14-2012 01:56 PM
PATS key system powerstroke6ltr Ranger & B-Series 8 09-20-2007 09:19 PM
Tags
16, 2003, 2007, code, excursion, f150, ford, freestar, key, pat, pats, pcm, relean, relearn, system, v10, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
