Exhuast smell - Ford Truck Enthusiasts Forums
Exhuast smell
Old 03-06-2011, 04:59 PM
Trueride Trueride is offline
Trueride is starting off with a positive reputation.
Exhuast smell
Greetings,
I have enjoyed reading your forum for several months now but this is the first time that i have posted, i'm very new to the world of diesel engines so any advice would be greatly appreciated. I just started getting a strong exhuast smell in the cab and would like to know if anyone else has had this issue or any ideas of what may be the cause. I have owned Fords before but like I have stated this is my first diesel so i'm not sure if this is something that can be expected. thanks
Old 03-06-2011, 05:31 PM
rickatic rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
Welcome to FTE...I suspect you are smelling an ongoing DPF regeneration. This would be normal. You should not be getting fumes in the cab though.
Regards
Old 03-06-2011, 05:41 PM
ctownson's Avatar
ctownson ctownson is offline
ctownson is starting off with a positive reputation.
I agree - this is probably happening during the regen process. One suggestion is to drive at highway speed and make sure it completes so it doesn't keep coming back due to not being able to complete the cycle.
Old 03-06-2011, 08:47 PM
Thanks for your input, i'll give it a try
Old 03-06-2011, 11:20 PM
marchare011's Avatar
marchare011 marchare011 is offline
marchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant future
Welcome to FTE
It could be as others are saying or it could be an actual exhaust leak. Read the following thread and see if it's similar.
http://www.ford-trucks.com/forums/10...st-in-cab.html
Old 03-07-2011, 08:15 AM
jim6090 jim6090 is offline
jim6090 is starting off with a positive reputation.
Don't wait. Schedule an appointment to get the exhaust gasket repaired. You should never smell exhaust, except while backing up.
Old 03-07-2011, 05:23 PM
BTyner41 BTyner41 is offline
BTyner41 is starting off with a positive reputation.
Welcome to the club. I too recently had an exhaust leak on my 2011 F250. Took it to the dealer who did a "smoke" test and discovered that an exhaust gas pressure tube bracket had come loose. After retightening the bracket, I have not had anymore exhaust smell in the cab. Go get it checked out. I waited thinking that it could be the active regen, but it didn't go away. A couple of hours at the dealer and no more nasty smell.
Old 03-08-2011, 03:59 PM
Sportscraft's Avatar
Sportscraft Sportscraft is offline
Sportscraft is starting off with a positive reputation.
As said I would have it checked. I had a strong exhaust smell in my 2004, especially when stopped, and was a big factor in me trading it in. I thought maybe it was from me covering vents and drilling holes when the stereo/subs were put in, but now believe it was a leak as other people describe. Passengers who weren't used to it really complained.
Side note, what do people think of the new smell. They show clips of it running inside with "no" exhaust smell - FALSE! Mine at idol gives off a distinct ammonia smell. Not as strong as the old diesels, but I like the old smell MUCH better. The 7.3s and dodge 5.9's in my opinion have the classic odor that I wish mine still had.
Old 03-08-2011, 05:37 PM
i did take all of the advice and made an appointment with the dealer which is next monday
Old 03-20-2011, 01:23 PM
Just wanted to give an update on the issue i had with exhaust smell....took it in to the dealer and the EGR tube was loose, so far so good....no more exhaust fumes in the cab.
Old 03-20-2011, 04:51 PM
chris60's Avatar
chris60 chris60 is offline
chris60 is starting off with a positive reputation.
Quote:
Thanks for reporting back, good to know, as that may happen to me or others!
Old 03-20-2011, 09:38 PM
Awesome! Thanks for the report.
2006 no boost Mickjman 6.0L Power Stroke Diesel 0 12-19-2016 11:02 PM
2000 v-10 oil leak TBarton 1999 to 2016 Super Duty 1 02-16-2014 03:01 PM
300 intake and exhaust manifold question juang316 Ford Inline Six, 200, 250, 4.9L / 300 7 08-15-2013 01:14 PM
bronco exhaust fordbronco18 1978 - 1996 Big Bronco 41 12-09-2009 11:21 AM
After market exhaust tip Bushwhacker 6.0L Power Stroke Diesel 4 06-19-2004 05:04 PM
Tags
2011, 67, ammonia, backing, bronco, car, exhaust, f150, f250, flex, ford, smell, smelling, smells, strange
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
