1st attempt at cab corner repair (pics) - Ford Truck Enthusiasts Forums
Old 03-06-2011, 04:17 PM
71mach351's Avatar
71mach351 71mach351 is offline
71mach351 is starting off with a positive reputation.
Well here you go. I know you guys like pictures. Here's my 1st attempt at welding and fabrication.
Inner cab before.
Inner cab afer after cutting out rust and fabing so pieces.
New corner fitment. Poor at best below the door pillar,
A little more fabrication and tweeking.
Another puzzle piece added.
More to come after welding it up.
Old 03-06-2011, 04:28 PM
vintage56's Avatar
vintage56 vintage56 is offline
vintage56 is starting off with a positive reputation.
nice big pics.
keep up the good work.
JML
Old 03-06-2011, 05:18 PM
rdemilt's Avatar
rdemilt rdemilt is online now
rdemilt is gaining momentum as a positive member of FTE.
Nice job correcting the fit, The PO of my truck welded them on as stamped, therefore the fit is not the best. I have plans to cut into them at some point and make the corrections as you did.
Rick
Old 03-06-2011, 07:34 PM
59JEEPSTANG's Avatar
59JEEPSTANG 59JEEPSTANG is offline
59JEEPSTANG is starting off with a positive reputation.
Looking good, keep the photos coming. Thanks.
Paul
Low budget carpet 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-14-2015 05:59 PM
53 progress update with pics 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-24-2014 04:34 PM
53 build update 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-28-2012 10:31 AM
Corvette Tail lights? 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 05-16-2012 12:06 PM
More cab corner replacement pics. 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-16-2011 10:58 PM
Tags
53, 77, 97, cab, cheap, corner, corners, cost, f100, f150, ford, pictures, repair, truck, welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
