Whats the best way to fix this frame damage (with pics)
These pics should probably go on the "Bonehead PO" thread. All of this carnage is the result of a homemade hitch. I am going to cut the hitch and bumper brackets off and grind everything down, but I want to add a class 5 receiver hitch and the frame is damaged in the area it needs to bolt on.
1. I'm looking for suggestions on the best way to repair this or..
2. I am looking for alternative hitch ideas so I don't have to repair it.
If you have to ask how to repair it, I am assuming you do not have a welder and can't repair it yourself. So take your pictures and go around to some shops and see if they will be willing to weld it up and repair it.
You could also go to the junkyard and get them to cut the back off a good frame, and cut the upper part of the good frame "C" off, and lay it inside your frame to repair it.
What we did.....
Just to finish up this thread, I will post up some after pics. I decided to knock it all back in place, weld it, and also weld in some support pieces. I am happy with the way it turned out, I still have to knock off the slag and paint it. I know the welds aren't perfect, but they should hold.
That's what my Dad's motorhome hitch did, got peeled down from dingy towing a S-10 Blazer for years. We pushed the dammaged frame back in place and also installed a 3' long, 3"x3" 1/4" thick angle bar which we ran along the botton of the frame rail. As my welder could not do that frame welding, we temp used bolts to hold it together and took it to someone with a bigger welder! With the additional metal angle bar running forward, there's no frame movement and the little Blazer no longer wagged behind the motorhome.
Lukes66
19
05-15-2016 01:24 AM
Lukes66
02-15-2013 11:17 AM
Lukes66
01-13-2013 09:18 PM
Lukes66
08-31-2009 08:39 AM
