how (not) to proffesionally remove a dana 60 carrier - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-06-2011, 01:34 PM
bill64's Avatar
bill64 bill64 is offline
bill64 is starting off with a positive reputation.
Old 03-06-2011, 02:18 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
There's a whole lot of stupid right there. They forced it out by pulling entirely on one side, so you can pretty much guarantee the case is distorted and bearing journals are ruined.
Old 03-06-2011, 02:38 PM
bill64's Avatar
cartmania I noticed that they pulled it from one side as well, most likely caused damage, I own a case spreader but never had to use it yet...rebuilt many gm corperate diffs and a few fords, the only dana's i rebuilt were 44's which the carrier was fairly easy to pry out, these guy's went too far to get the diff apart !
Old 03-06-2011, 02:45 PM
Yeah, I changed my D60 and 10.5 gears without a spreader, just carefully used pry-bars to get the carrier out.
Old 03-07-2011, 02:08 AM
fz1dave's Avatar
fz1dave fz1dave is offline
Super Duty
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
Redneck needs to learn how to hold a camera still. Not that it matters I suppose.
1996 f350 dana 60 axle seals Codymiller 1987 - 1996 F150 & Larger F-Series Trucks 0 03-17-2015 05:09 PM
Dana 60 Carrier Spider Gear Question Zazoos 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-11-2015 11:12 PM
Dana 60 ?? Bud Mud 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-05-2014 09:48 AM
Dana 60 carrier 97puller Ford Truck Parts for Sale 1 06-28-2013 04:44 PM
Will a Dana 60 carrier fit into the Dana 50 housing? mando jake 1999 to 2016 Super Duty 13 03-24-2008 08:13 AM
Tags
2003, 60, carrier, dana, detroit, diesel, disassemble, duty, f250, ford, front, removal, remove, removing, super, superduty, truetrac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
