electric fan - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
electric fan
Old 03-06-2011, 01:46 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
electric fan
Is it worth swapping one in? Anybody has one installed and what you think of it? Found one today for our trucks, and think its atta fair price.
Old 03-06-2011, 02:56 PM
Night Crawler Night Crawler is offline
Night Crawler is starting off with a positive reputation.
What did you find?
they sure do free up some HP
Old 03-06-2011, 04:09 PM
BadDogKuzz's Avatar
BadDogKuzz BadDogKuzz is offline
BadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud of
All the ones I have seen for our trucks are big bucks. So what it you find?
Old 03-06-2011, 04:15 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
I rewired a baby electric fan from a truckstop with a lighter adapter and set it in my middle console cup holder to speed up the cooling in the back for the kids, purdy neat but no HP gains, lol. I know Timmy, just a lttle nuts this morning. On a serious note, a little extra cooling is never a bad Idea but the cooling compacity of our trucks is more than efficiant from what I learned here. Others will weight in their thoughts..
Old 03-06-2011, 04:22 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
If you're referring to going with an electric fan setup on the radiator vs. the stock water pump mounted unit, here's the pros and cons as I know them:
PROS:
less strain on engine
frees up a few ponies
possible gain in mpgs
more precise control of fan engagement through electronic thermostat
CONS
not suitable for regular or heavy towing due to reduced airflow
tends to be pricey for prefab kits
So basically if you tow "light & little" an electric fan setup could get you better mpg - how long to recoup the cash outlay is quite variable. If you tow "hard & heavy" then leave the stock setup in place. Otherwise you'll probably cook your engine.
Old 03-06-2011, 04:28 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
Ok, our trucks and diesels in general are very thermally efficient - but the cooling system is what it is for a reason. The bottom line is, it works and works well - even in 100*+ temps, pulling loooong grades with a load, while keeping the AC cold. I can tell you from experience a weak fan clutch is all it takes to upset that balance.
Someone will have to explain to me how a 1/16HP electric fan can replace the 27HP the stock fan allegedly uses...
Once upon a time, electric fans and even 'no fan' mods were all the rage. IIRC, it only took a few broken motors to end the 'rage'.
Old 03-06-2011, 04:47 PM
rat49f6's Avatar
rat49f6 rat49f6 is offline
rat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to behold
interested to see what the pre fab options are because i have no choice but to run an electric fan
Old 03-06-2011, 05:01 PM
Quote:
98-03 Ford Super Duty Diesel Electric Fan
Its actually (2) 1/16 HP motors. Lol.
Run a 'real' coolant temp gauge. All ya gotta do is take yer foot out of it when it runs hot. You already turned the AC off!
Old 03-06-2011, 05:11 PM
for 800$ I'm good, they can keep em
Old 03-06-2011, 05:24 PM
rat49f6's Avatar
yeah ill probablly make a set up with 2 double fans from the junk yard
Old 03-06-2011, 05:37 PM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
Somewhere on this site I read that the fans from Lincolns work. Not sure where I saw it.
Old 03-06-2011, 05:38 PM
Taurus fans are 4000cfm on 'high' and 2500cfm on 'low' IIRC. And they are $20ea all day at boneyards. Maybe you can find a fabricator to build a shroud for them...
rat49f6's Avatar
hmm any idea of the Lincoln year and model??
Old 03-06-2011, 05:45 PM
trike1946's Avatar
I seem to think I saw it in the OBS forum. I'll try and find it.
Old 03-06-2011, 06:13 PM
milleroutdoors's Avatar
milleroutdoors milleroutdoors is offline
milleroutdoors has a very good reputation on FTE.milleroutdoors has a very good reputation on FTE.milleroutdoors has a very good reputation on FTE.milleroutdoors has a very good reputation on FTE.
The Taurus fans I believe are very similar to the lincoln fans, don't know the years but they were in front of the 3.8 liter engine. Lot's of off road rigs have them for more cooling at low rpms. I have a couple of them to install on my '79 if I ever get around to it. You also can get the thermostat unit that mounts inline of the radiator hose, for automatic use, as well as controlling from the cab the speed (2 speeds) and shutting them off.
Slow Server? krooser 1987 - 1996 F150 & Larger F-Series Trucks 11 05-05-2015 08:39 AM
Is reverse osmosis as good as distilled water? sparkkky 6.0L Power Stroke Diesel 7 03-25-2011 01:12 AM
Leveling kit michaelsmith9391 1987 - 1996 F150 & Larger F-Series Trucks 17 02-10-2011 08:31 PM
Canton Racing 4x4 Oil Pan dragthepaint 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 7 05-16-2010 05:59 PM
Sunroof? buckeyebronco 1978 - 1996 Big Bronco 12 10-08-2008 09:33 AM
Tags
03, 2000, 2001, 73, 99, cons, cool, diesel, electric, f250, f350, fan, fans, ford, mpg, passengers, pros, prosandconsofaelectricfaninadiesel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
