Dana 50 vs Dana 60?
Dana 50 vs Dana 60?
So I've been trying to do some research of the difference, and pro's-con's. I know the D60 is heavier duty and has larger parts, and the D50 is kinda a beefed up D44. But I have not found anything that relates to my model of truck. Nor info on upgrading, I've only seen upgrade from D44 info.
I currently have a D50 that needs some tlc under my truck, probably needs the gears replaced, needs some u-bolts replaced, and some of the steerig bars also replaced. So I was thinking, why not replace it with a D60, but everyone up here seems to think their made of solid gold. $1200-2500, or my personal favorite $850 for just the carrier, no axles.
The largest I plan to run is like 35-37's with like 4:10-4:56's. Would that put un-needed strain on the D50 to the point were it would break, and a D60 is the way to go, or would I be better served to just spend the couple hundred to rebuild my axle?
Also lift kits, with the D50, do I go for stock F250 kits, or F350. As some depend on the axle, and they seem to forget my axle exists.
all the info you need is here, from the pages of it i read through.
Front axles: Dana 50 vs 60 - Page 2 - Pirate4x4.Com Bulletin Board
i did the swap, my D50 was worn out and looser than a cheap lady of the evening, i am a die hard solid alxe guy though. i found my 60 and a 10.25 Stearling rear for 650 for both. didnt need the rear but i thiugh what the hell for 650. it even had the right ratio. after the rebuild and including the axles i had about a grand in it total.
Man i feel lucky. I got my complete parts truck (86 f350 4x4) for 500. I will be swapping out both axles this spring to my Bronco. Still have to find a place to store all the parts i want to keep off her lol. I also have been searching for the last 2 yrs for a d60 for mine. All the yards around here wanted about $1000-1200 for a solid front. That didn/t include any of the hardware either.
Folks around here seem to think they're made of gold also. Averaging around $800-$1,200. Lowest I've seen is $600.
10.25 rears go for $200-$400.
A D50 could be rebuilt much cheaper than the purchase, rebuild, and installation of the D60.
But if you're lifitng it, running big tires, probably managing the throttle with a heavy foot...sounds like a Dana 60 might be up your alley.
I plan to run the standard F150 5 lug 44 TTB under the diesel in my 65/95 F150 Mutt until it blows up, shouldn't take long to pop that inner U-joint. By then, I'll have a Dana 50/10.25 setup ready to install. I've got a line on a D50/10.25 combo with 3.55 gears for $300. Compare that to the price of a 60/10.25.
I think the dana 50's a pretty good. They use the dana 60 outers, The dana 44 ttb hd case, and a bigger ring gear than the dana 44 and 44hd. I also believe they have more splines, I do know they corrected the major failure point on the dana 44's with the dana 50. My 91 has a dana 50 and it seems it has plowed all its life. Its still under the truck too.
Yeah the D50 is a half decent axle, I was thinking if I did get a D60, I'd hold onto it for a bronco/F150 bush truck. Something I want a good sturdy front axle, but if it ends up F.U.B.A.R. I'm not going to cry that that axle cost me $1000, and now I gotta drag the truck outa the bush to get it....
