Fuel leak 97 f450 7.3
I have a 97 f450 2wd 7.3. I took it in to get some tires and oil change and when they rolled it out of there shop I noticed it was leaking something. It sat running for about 2/3 min and in that time a puddle of fuel about the size of a basketball had collected on the ground. We found that it was puddling on top of the motor and running down onto the ground. The mech. told me that the fuel regulator valve was leaking and pointed to a silver device on the top rear of the motor. I've had the truck for about a year with NO LEAKS OF ANY KIND. Anybody have any ideas what these guys might have messed up. To me it looks like maybe someone leaned on a fuel line or something and broke it?????
thanks
macon
thanks
macon
These engines don't have a regulator itself in the back ofthe motor, it's on the fuel bowl smack dab in the middle of the valley, there's 2 fuel lines in the very front running to the bowl, a mechanical pump in the bellows of the valley of death immediately behind the fuel bowl and a few lines that are real short that run in between the pump and bowl which do have a tendency to crack and leak. Lastly there is a brass banjo nut that goes in the back of tue fuel pump that joins the 2 lines that feed the back of the head. They can leak by the fittings but it's more of a gradual if anything kind of leak.
And when I figure out how to post pics I will.
Thanks
In case I miss it later (CAPS game @ 1700) Here is how I post my pics:
https://www.ford-trucks.com/forums/1...l#post10059648
here is what the told me was the fuel reg. valve and that it was leaking.
now they are tellin me its an o-ring on a fuel line that goes into the filter housing.
Looks a little wet up there but once agin i had no leakes before i took it into them.
They said they gonna fix it a no cost, so i think they found out there guy did something.
entropyjones
25
10-10-2015 11:18 AM
1BADRIDE
10-30-2011 08:36 AM
Canuck Safeman
33
09-27-2010 08:12 AM
