Pilot bushing/bearing removal - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 03-05-2011, 09:46 PM
jiveturkey692000's Avatar
jiveturkey692000 jiveturkey692000 is offline
jiveturkey692000 is starting off with a positive reputation.
Whats the best way to remove the pilot bearing or bushing, whatever its called? Monday night I am putting in my solid flywheel and clutch from valair and the new pilot bearing and am not sure how easy the original is going to come out.
Old 03-05-2011, 09:57 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
You have a used flywheel?
or your using a used bearing?
The valair kit comes with a new pilot bearing.
Kinda confused on what your asking.
I used a socket to put mine in.
Old 03-05-2011, 10:03 PM
I thought it was pretty clear lol, I want to know how to remove the old pilot bushing? Wasnt sure if it was called a bearing or a bushing. But I just want to know the best way to remove the old one. And its a new clutch and flywheel from valair with a new pilot bearing that I am putting in.
Old 03-05-2011, 10:06 PM
Talyn's Avatar
oh, your just playing.
Just use a socket or something to hammer it out from the back side of the clutch.
there are bushings and bearings for the pilot.
Old 03-05-2011, 10:13 PM
I thought the bushing was pressed into the back of the crank shaft?
Old 03-05-2011, 10:23 PM
Talyn's Avatar
no, its in the flywheel.
Midnight Mods: Dual Mass Flywheels For Dummies
There is a hole in the center of the flywheel, you just press or hammer it into the face and make sure its flush.
Old 03-05-2011, 10:40 PM
Thats cool, the only experince I have with the pilot bushing is in older GM's. They are pressed into the crankshaft. They are fun to get out. This will be much easier, Thanks.
Old 03-05-2011, 10:53 PM
Talyn's Avatar
Cheers bro! =)
Pilot Bearing or Kevlar Bushing swade-o 1999 to 2016 Super Duty 7 11-17-2015 12:24 PM
Pilot bearing questions, 6.0 Pilot bearing? Ninetynine7.3 1999 - 2003 7.3L Power Stroke Diesel 9 03-02-2015 10:37 AM
Pilot bushing removal zak8tac 1973 - 1979 F-100 & Larger F-Series Trucks 7 08-10-2011 03:34 PM
What Pilot Bearing to use in a 400, with a ZF 5 speed johnnyvpp 1973 - 1979 F-100 & Larger F-Series Trucks 9 06-01-2010 08:37 AM
Pilot Bearing Removal?? Truxx1956 Clutch, Transmission, Differential, Axle & Transfer Case 5 07-11-2008 09:23 AM
Tags
292, 350, 360, bearing, bushing, cherokee, f350, flywheel, ford, output, pilot, removal, remove, shaft, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
