Best Way To Heat WVO to Make Biodiesel - Ford Truck Enthusiasts Forums
Old 03-05-2011, 08:43 PM
sirnobody sirnobody is offline
sirnobody is starting off with a positive reputation.
Hey everyone,
I'm working on a prototype biodiesel processor which uses a pump to mix the wvo instead of physically stirring it. I had an idea to put a brass fitting in the middle of the tube and then attach a heating element to it, with insulation, to heat up the WVO as it passes through the tube. This is a bit different than the standard way of heating WVO by immersing a heating element into the WVO and I was wondering if anyone had tried this or which is more energy efficient or heats faster etc. any comments appreciated
Sirnobody
Old 03-05-2011, 11:19 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
Think I read somewhere that bio attacks Brass... Fabman???
Old 03-08-2011, 08:21 PM
tabascom16 tabascom16 is offline
tabascom16 is starting off with a positive reputation.
Water heating element does the job. Plus they are very cheap.
Old 03-09-2011, 04:01 PM
binuya's Avatar
binuya binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Quote:
Originally Posted by sirnobody View Post
Hey everyone,
Sirnobody
Are you talking about an inline heater like the one below? They're great, just make sure your pump is running when it's on. Many prefer the inline heating set up.
Enlarged View of Product
Old 03-09-2011, 04:17 PM
Yep...works like that to inside a 1" pipe. Inline or in the side of your processor...either way it serves the same purpose.
Old 03-09-2011, 04:34 PM
binuya's Avatar
Quote:
So is that the setup the OP is referring to? I am unclear as to what is meant by the brass fitting.
Old 03-09-2011, 10:56 PM
It wouldn't matter if you used a brass, steel, cast iron, or whatever material for a fitting (he probably just had a brass unit on hand or is worried the chemicals in the process will eventually eat other materials). The heating element needs to be immersed in the oil no matter what its location is...either in the piping or in the reaction vessel. As long as you are circulating fluid past the heating element you will have a much more energy efficient unit than if the liquid were to stand still.
For example a chunk of ice will melt quicker in 60 degree water that is being circulated versus being immersed in 200 degree water that is just standing still.
Old 03-10-2011, 10:40 AM
binuya's Avatar
I understand how an inline heater works. I have one on my wash tank. My posts were actually directed at the OP.
Old 03-10-2011, 01:30 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Because of two small fires in my processor I switched over to indirect heating and now my oil never touches the eliment.
Old 03-19-2011, 02:12 AM
Sorry for the delay, I decided on an immersed one for my prototype biodiesel rig im making out of a an old paint can. Im going to step it up to a five gallon bucket later on since i dont have a diesel vehicle and im doing this more for the novelty than anything. I was referring to an inline heater versus a direct, in the main tank immersed, heater and was wondering which is more fuel efficient.
Old 04-21-2011, 12:04 AM
neader neader is offline
neader is starting off with a positive reputation.
Going BIO frist time
Hi every body
I have a 1997 F-250 7.3 power stroke and want too go bio should I
use a 14% methenol or 22%
Processor setup sirnobody Bio-diesel, Propane & Alternative Diesel Engine Fuels 5 06-07-2011 05:24 PM
The pros and cons of homemade biodiesel vs wvo. derherr65 Bio-diesel, Propane & Alternative Diesel Engine Fuels 66 04-23-2007 09:23 AM
Heating WVO, what kinds of pipe to use? Orpackrat Bio-diesel, Propane & Alternative Diesel Engine Fuels 6 10-14-2006 01:03 AM
WVO - the best idea parkland Bio-diesel, Propane & Alternative Diesel Engine Fuels 17 03-27-2006 04:02 PM
Biodiesel/Vegetable Oil peterjeff Bio-diesel, Propane & Alternative Diesel Engine Fuels 27 01-21-2005 07:28 PM
Tags
2004, biodiesel, efficient, f250, flex, heat, heater, inline, make, mercedes, pipe, processor, reactor, ways, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
