radiator question - Ford Truck Enthusiasts Forums
radiator question
Old 03-05-2011, 07:24 PM
almonyspm1 almonyspm1 is offline
almonyspm1 is starting off with a positive reputation.
radiator question
i just ordered a VistaPro radiator. its a four-row with copper and brass tanks. what does the copper and brass do compared to plastic? and is this a pretty good radiator compared to stock 2-row from 302?
Old 03-05-2011, 07:36 PM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
Should be fine. What copper/brass tanks do compared to plastic is not leak. I need to replace my radiator when I'm ever home again.
Old 03-05-2011, 07:54 PM
okay, well no leaking is good haha. i have 92 f150 nite edition. its a such a beautiful truck man. hardly and rust spots on the frame, none on the fender wells over the wheel, no frame rot whatsoever. i rear-ended somebody and need to replace my whole front end. new bumper, stone def., grille, headlights/parking, core support, air condit, cond., rad., and fan. when i got in the accident i almost cried hahaha its gettin there though and ill keep you updated on the brake situation
Old 03-05-2011, 08:03 PM
zxwut?'s Avatar
whew....
Good luck with the rebuild. I'm sure you can get it looking nice again.
Old 03-05-2011, 08:43 PM
Ed Bamba Ed Bamba is offline
Ed Bamba is starting off with a positive reputation.
Just wondering, is this the one you're getting Vista-Pro Ready Rad 436009 - Vista-Pro Ready-Rad Radiators - Overview - SummitRacing.com ? If so, did you get it from Summit, or somewhere else?
Old 03-05-2011, 09:20 PM
CWPottenger CWPottenger is offline
CWPottenger is gaining momentum as a positive member of FTE.
Quote:
They last longer, leak less, and "radiate" heat better for a more efficient cooling system.
Old 03-05-2011, 10:47 PM
i ordered it from summit. is there a problem with that or were you just wondering
Old 03-06-2011, 09:30 AM
No, just wondering since I'll be needing to replace mine in the future and was looking for a good replacement.
Old 03-06-2011, 09:50 AM
oh alright, well i should be getting it Tuesday or Wednesday. ill post on here how it works out
Old 04-07-2011, 09:58 AM
CS45's Avatar
CS45 CS45 is offline
CS45 is starting off with a positive reputation.
Um, I was looking at the description of this rad and it states under "material" that this is made from aluminum and plastic.
You said your new rad was made of brass and copper.
Is that the right rad from Summit? I'm looking at replacing my rad also because one of the side tanks (plastic) is leaking and want a brass/copper one.
I found a 4 row Spectra Premium Radiator with the same part number 436009 at Auto Zone for $268.99 which has no plastic.
Do I need to worry about a different fan shroud?
Any thoughts?
CS45
Radiator options Ford_Six 1967 - 1972 F-100 & Larger F-Series Trucks 7 10-18-2012 08:49 PM
radiator oldfordcoupe 1961 - 1966 F-100 & Larger F-Series Trucks 0 07-10-2012 09:06 PM
Radiator - which to choose? carbs & chrome 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-24-2012 05:57 PM
Aluminum vs. Copper/Brass radiator 48fordcoe 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 05-19-2009 09:21 PM
diesel engine cooling drewdole1 1987 - 1996 F150 & Larger F-Series Trucks 4 07-27-2008 08:20 AM
Tags
2004, 2008, 436009, f250, ford, leak, rad, radiant, radiator, ready, small, sport, trac, vista, vistapro
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
