97 F250 Front Gear Ratio Help! - Ford Truck Enthusiasts Forums
Old 03-05-2011, 04:38 PM
Johnboss Johnboss is offline
Johnboss is starting off with a positive reputation.
Exclamation 97 F250 Front Gear Ratio Help!
Hello,
I used to be on under a different name but changed email and lost my login. Anyways, here is my problem.
I have a 1997 F250HD 4x4 extended cab with the 460 in it. It has a Dana 50 TTB front axle. I need to replace my differential but can't find the gear ratio. I have searched everywhere and can't find the bill of material anywhere on the axle, here is what I have found.
-Axle code on door sticker: C5
-These are the numbers I found on the front of the diff cover between the fill plug and passenger side.
P664 7 1
41583c
1945
I have looked everywhere for anyother numbers but can't seen to find any. Any help would be GREATLY appreciated!!!!
Thanks,
John
Old 03-05-2011, 05:14 PM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
Should be stamped on the diff. If you can't find it, look at the rear. It's the same.
Old 03-05-2011, 05:45 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Axle code on door sticker: C5 = 4.10 limited slip.
edit;
so that means you're looking for a front axle to match 4.10's (technically they're 4.09 gears up front.)
your front axle is called a D50 (dana/Spicer 50.)
however a D60 straight axle will bolt directly in its place (a common mod for off roaders/those with lifted trucks/plows,and those just with money to burn lol.)however the springs should be swapped as well,to those used with the D60.then you would need raise the rear axle 2" to match the increased lift of the front as well.this would essentially turn the truck into an "f350" with only the stickers door jam sticker differentiating it between the "f250".
rear axle identification deezdrama 1968-2013 Full Size Vans 12 09-01-2016 08:16 PM
Dana 60 and Dana 70 Axle ID Help 78 Ford F150 460 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-15-2016 03:52 PM
Axle ratio identification help FastGilla 1987 - 1996 F150 & Larger F-Series Trucks 5 04-21-2011 09:25 AM
gear ratio identification blueovalbigblock 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-21-2010 12:11 PM
D60 Gear Ratio DILLIGAF13 Offroad & 4x4 9 10-18-2008 01:11 PM
Tags
1997, 50, 75, 95, 97, auto, dana, engine, f250, find, ford, front, gear, ratio, ratios
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
