Traction control override???
When we recovered my wife's little boat at a shallow sand ramp, the Hybrid Escape would not come off of idle and pull the boat put of the water.
In order to get the trailer deep enough to get the boat, I had to back the Escape until all four tires were wet. I winched the boat onto the trailer. When I stepped on the gas pedal the engine just sat there in idle - even when the pedal was fully depressed.
I backed the Escape an inch deeper into the lake and then put it back into drive and made a little progress. I repeated the rocking (reverse to drive) and the engine came alive and easily pulled the boat out.
I am wondering if there is a way of turning off the traction control system for times like that? Has anyone else had this problem?
Has anyone else had a similar problem? It has me concerned that this might not be the vehicle that I need to launch the boat. The boat is an aluminum 1962 Lund runabout with a 50 hp motor - it is pretty lightweight.
If it isn't traction control, then I wonder what it was that prevented the engine from revving and yanking me out of that lake? It was pretty unnerving to have it just idling when I had my foot to the floor. I tried several times before I finally woke it by rocking.
Thanks
Not sure but you may have better luck getting an answer about a Hybrid by posting it at Ford Escape Hybrid - GreenHybrid - Hybrid Cars.
There happens to be a somewhat similiar post there right now: 2008 FEH Transmission acting strange - GreenHybrid - Hybrid Cars.
I got my answer at the GreenHybrid forum, but since I raised the issue here I thought that I should follow up for FEH owners that might be interested.
It seems that the FEH is equipped with a 'stall sensor' that protects the electric motor from overheating in a stalled (stopped) condition. This is a feature that FEH ought to know about before they find themselves freaked out like I was.
You can read about it here: GreenHybrid - Idle threat on a boat ramp
Rusty16
Escape & Escape Hybrid
02-17-2017 06:53 PM
alanber
1999 to 2016 Super Duty
08-18-2015 08:46 PM
Morgueman
1997-2006 Expedition & Navigator
01-05-2014 12:04 AM
rbarbot2
10-03-2010 03:35 PM
