Icon rear blocks wont work?
Ok so I found out that Icons 4.5" lift kit wont work for my truck because of the rear blocks they make "flat" and I need "tapered blocks"? Also they blocks they send me are 5" and my factory blocks are 2" so that means that me rear will be lower than my front by 1". At first I was going to use Icons 6" block to make the rear level with the front.
This is my trucks info: 2005 Ford SuperDuty XLT SuperCab V10 4x4 FX4 Shortbed
Is the block problem because I have a supercab and a shortbed?
Thanks
~Gage~
Thanks
~Gage~
A 5" block should put you about level, or slightly high in the back. I have an Icon 4" lift in front with 5" blocks and have about 1.5-2" of rake. I've actually thought of dropping down to a 4" block. A flat block is fine for you because you have a one-piece driveshaft. Flat is really what it SHOULD be because with a one-piece driveshaft you want the transfer case output and pinion parallel. If the pinion is pointed up at an angle you can get driveline vibrations. Ford seems to randomly use flat or tapered blocks without paying attention to the pinion/output shaft angles.
Yeah, I think the 5" Icon blocks will be enough. You might want to contact Icon to be sure, or TruckToyzPerformance, they do a lot of Icon lifts. Since yours is a gasser, it will sit slightly higher in the front than a diesel. 6" is a really tall block, and if you need that much I would go with a spring lift in the back. TruckToyzPerformance also has a gallery you can look at different lift configurations: Gallery
Thanks for the info cartmena, Theres conflicts about the taper vs. flat blocks. Some guys are saying that I need the taper because of my 1-piece driveshaft, short box, super cab. Others say it doesnt matter? I am worried about vibrations from the driveshaft. I dont know what to do.
~Gage~
~Gage~
A lot of people are misinformed about block angles. With a one-piece driveshaft, you want the transfer case output and pinion to be parallel. A flat block achieves this. When you get to really high lifts (6" +) then the u-joint angles get pretty high, and at that time an angled block can help, but it's the lesser of two evils.
I just found this today.
Icon Vehicle Dynamics Suspension Question: Why are the new blocks flat?
"Icon Vehicle Dynamics's engineers have conducted numerous tests' regarding both flat and angled blocks. The conclusion was that flat blocks do not disturb the pinion angle of the rear end and prevent excessive wear and vibration from occurring. Icon Vehicle Dynamics's flat blocks optimize spring travel and have a built-in bump stop tang much like the factory blocks."
~Gage~
~Gage~
