How bad are they???
Old 07-15-2015, 08:20 PM
ryan94long's Avatar
ryan94long
ryan94long is offline
How bad are they???
So I am looking at a 2005 5.4l tomorrow and before I went to look at it I wanted to read up on it and I have heard some pretty serious horror stories. So I simply want to know how bad are they REALLY? Is this an EVERY single truck problem or a 1 out of 100? also what should I listen for? Just a basic tick? or diesel knock? Also is there anything else I should look for when test driving this vehicle?
I appreciate your time guys!
Old 07-15-2015, 09:07 PM
bowkill's Avatar
bowkill
bowkill is offline
Only had one and no tick. 2004 5.4 SCREW 4x4. 165K. Only PM and an alternator.
Old 07-15-2015, 10:44 PM
F150Torqued's Avatar
F150Torqued
F150Torqued is offline
Only have personal experience with one '04 5.4L 3v. Only regular PM (+ O2 sensors, VCT Solenoids). Over 200k mi and it has ticked and sounded like a diesel at idle every damn one of those miles. Countless people have asked me "What's wrong with your truck!!" But everything is still original and it's still running original alternator, A/C, water pump, PS pump, starter, idler pulleys and even serpentine belt - and it idles with good oil pressure on an aftermarket gauge.
If you read all over this, and other forums, you'll find 99% of the complaints center around the "sounds" the 5.4L makes - even AFTER many users replace all the timing components, they still make the same noises. You see very few that crater because of it. That's my 2 cents worth. I'd say base your decision on all the other usual things about buying a used unit.
Old 07-17-2015, 09:31 PM
srb1194's Avatar
srb1194
srb1194 is offline
Mine has been excellent. Only unexpected things were a starter and a blend door repair. If it has been well maintained I would trust it, if not I wouldn't.
Old 07-17-2015, 09:46 PM
07F150Lariat5.4's Avatar
07F150Lariat5.4
07F150Lariat5.4 is offline
2007 5.4L 3V. 131,000 miles. No noticeable tick or anything. Have never had an ounce of issues. I just keep it maintained well with frequent oil changes and filters using all Motorcraft products. Runs like new. It mainly just depends on how well it was taken care of.
trekbasso
18
01-22-2013 12:37 PM
jackstraw
12-05-2012 01:32 AM
rolltide3006
16
04-23-2011 10:50 AM
photomac
08-15-2007 09:20 PM
MustangGT221
04-12-2005 07:41 PM
Quick Reply: How bad are they???
