valley pan cdr hole size?
Ok I am getting the parts together for my cdr delete system and need to know the size of this hole/grommet. I finally got the filter canister done and a place on the frame to mount it. If it works as it should I will move the outlet hose up on to the driverside valve cover. I figure it will be better off up there when I can finally get around to the custom manifold/turbo set up in the future.
BeerCan500
08-23-2012 10:09 AM
