What rear end does my F250 Have in it? - Ford Truck Enthusiasts Forums
Old 03-05-2011, 07:57 AM
Mongrel Mongrel is offline
Mongrel is starting off with a positive reputation.
My '96 F250 351 4x4 with E4OD does 2,000 RPM to go 70 MPH with stock tires on it. What rear ends does it have? Is there an easy way to find out? I'd like to get a few more miles per hour with less RPMs. I know I can put taller tires on it, but the stock tires that I have are almost new, so they'll be here for awhile.
Old 03-05-2011, 08:19 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Look at the axle code on the door sticker and compare with a axle decoder chart.
Or get under and look at the tag on the axle which should have the actual ratio stamped on it.
Old 03-05-2011, 08:20 AM
So I looked under the truck and saw a sticker on the front axle. It says 4.10 on it, so i guess that's what it has. D-4 8 0-A was written on the sticker. The front axle is not a solid axle, it flexes in the middle.
What is the feasibility of switching the 4.10 out for a higher gear, like a 3.73?
I should explain that i don't plan on towing anything with it, I will mostly use this truck like I did my last one, for summer masonry work, which will occasionally stress the truck but not too much.
Old 03-05-2011, 08:42 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
It is not going to be cost effective to switch gears. You are looking at between 500-1000 PER axle to change gears and you need to do both. Even IF you were to get 2 MPG better it would take 30,000 miles just to brake even on the gear swap cost. And that is if you get the gears changed for 500 per axle. Make it 60,000 miles if you pay a 1000 per axle(more likely)
Old 03-05-2011, 11:43 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
2000rpm at 70mph with 31" tires is 3.55 gears, check the axle code on the drivers door decal, should he H5. You don't want anything higher(numerically lower) than this ratio in a truck this big, milage will get worse not better.
Old 03-05-2011, 12:33 PM
Do the axles themselves have to be switched out also?
Old 03-05-2011, 02:01 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
You can just swap out the gears inside the differential.
Old 03-05-2011, 02:37 PM
IDIDiesel John- That doesn't sound that bad. I thought that maybe the whole thing had to be all taken apart. Who sells gears? I got 246k out of my last truck and this one has only 155k, so I think it might be worth it to do the gear swap. I'm going to take really good care of this truck, I even got some rust fixed at a body shop, which was a first for me... Plus, I used to turn wrenches full time years ago, so think I'm handy enough to do the swap myself.
Old 03-05-2011, 03:16 PM
You can find gears from a junkyard. Or the entire axle if the price is right and you wanna save abit of time.
Old 03-05-2011, 06:31 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
2k rpm @ 70 with the E40D sure sounds like 3.55's to me too.
my suggestion,rather than swapping in aftermarket gears like 3.08's into a truck used for masonry,would be to just slow down to 60 mph to help improve fuel economy.not much helps fuel economy going 70 mph.too much wind resistance.
the sticker lazy k was referring to,is on the inside of the drivers door jam.there's an axle code there.not on the axle itself(however the is a tag on the axle that shows the ratio,though it's close to the bolt,and may be hard for the novice to understand it.)
Old 03-05-2011, 06:58 PM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
If it is 3.55, I would definitely not go any higher.
Old 03-05-2011, 09:18 PM
The sticker says 4.10 on it pretty clear. The stock tires are p235's. the 2000 rpms at 70 mph is obviously somewhat variable depending on the terrain, as I've been driving it up and down the appalachians of western MD. Maybe I should just get a set of taller tires... I had an old crown vic police model that did 80+ mph on 2000 rpms out of almost the same engine, but I know that is comparing apples to oranges.
Old 03-05-2011, 11:29 PM
Umm P rated car tires on a 3/4 ton 4x4 truck? Yikes! That ain't passing a safety inspection anywhere that I know of!
Still fine of you ask me, but as long as you use that truck nothing other than to load groceries in the box.... just the empty weight of the truck alone the tires are at their maximum load capacity.
Old 03-06-2011, 08:02 AM
Sorry about that, its got LT235's on it. What diameter in inches is that comparable to? I put 285's on my old F250 and had to cut back the front bumper just to fit them on, but they were awesome. What percent final drive reduction would 275's get me? It might be easier to do this than to tear the rear ends apart. Plus, it would be bad a$$ to have the truck sitting even higher with more ground clearance.
Old 03-06-2011, 09:25 AM
zxwut?'s Avatar
Quote:
A 235 should be around 9 and a quarter inches, but that can vary between manufacturers. Also, you can't figure the final drive by width, you need to post up the height ratio also, so 275/whatever.
How to tell wich gear set in rear end 1950F2 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-05-2016 11:21 PM
Gearing back to stock ratio? 71ford801 1967 - 1972 F-100 & Larger F-Series Trucks 5 03-02-2016 08:21 AM
wtf? burnout trouble cws10190 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-10-2012 10:19 PM
Anti roll system with bigger tires Myf350sd 2009 - 2014 F150 10 02-19-2012 11:51 AM
f150 to f250 rear end blue92'f150 1987 - 1996 F150 & Larger F-Series Trucks 0 04-03-2011 12:30 PM
Tags
200, 2000, 96, axles, duty, edn, f250, f350, ford, have, kind, reae, rear, rearend, straight, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
