1995 F150 XLT won't start
I've been having the same problem.
I would suggest you pull a plug and ground it, get someone to turn it over and see if it fires. Take note if it is strong blue spark.
If you have fire, try spraying some starter fluid into the throttle body and see if it hits.
This should determine if it is an ignition problem or a fuel problem.
Hope this helps.
Hope this helps.
Jayme Duty
22
04-04-2010 05:12 AM
rebal
04-07-2001 04:00 PM
