95 PSD E4OD won't go into drive - Ford Truck Enthusiasts Forums
Old 03-04-2011, 10:04 AM
JermKline JermKline is offline
JermKline is starting off with a positive reputation.
Hi all...
I've been searching this thread for a solution to my problem but since transmission problems can be varied, none quite matched.
My rig is a 1995 F-250 Powerstroke 4x4 with 150k on the clock and an E4OD. It has been well maintained and no major work performed aside from glow plugs recently... That was fun! But that's another story...
The issue: Irregularly and randomly over the last year or so the truck has had a problem going into drive. I'll hop in, put it in Drive and nothing. It's like its in Neutral. It is also the same in 1 and 2. If I put it in Reverse, I can feel it engage and the starts to go in reverse. When it has this drive issue, the only thing that I can do to make it go is to give it some fuel and idle it up. Then it slowly engages and its fine.
**EDIT** Last night it did this... But this time when I could only get it to go by putting it in first and then giving it fuel... It slowly engaged.
Overall its done this maybe five or six times over the last year and doesn't seem to be getting worse. Sometimes it will go for a month with no issue.
This has happened when its warm or cold so I'm not sure heat is an issue. About 10,000 miles ago the transmission was flushed / full service. Oh, and the ATF level is exactly where it should be.
My biggest fear is that the transmission needs a rebuild. One local shop quoted me $4200 to rebuild it.
What I'm looking for is to know if there is a simpler and cheaper fix. I'm not really interested in a rebuild, unless that is the only option.
So, any ideas? My fingers are crossed for a simple fix.
Old 03-04-2011, 06:56 PM
jk080's Avatar
jk080 jk080 is offline
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
I would think that you have made sure that the level of trans fluid is correct.
If the level is correct there are a few things that come to mind that can cause the delay into drive, but they are all problems inside the trans that would require the removal and inspection of the trans.
I would at least get another opinion on the trans from a different shop, there is only so much someone can do over the internet.
The price you have been quoted seems high to me, we do these with all the updates, shift kit and converter for around $2400 to $3000.
Old 03-04-2011, 08:04 PM
gsmoljan gsmoljan is offline
gsmoljan is starting off with a positive reputation.
codes
did you hook up scan tool and see if there are any codes like 628 converter slippage or 629 solenoid circuit failure 632 tsc did not switch state
Old 03-04-2011, 09:41 PM
Yep, fluid level is correct. And thanks for the info. When I was told $4200 for a rebuild, I choked a little.
I just had my buddy hook his code reader up to it and he said it wasn't throwing any codes. Assuming he was running it correctly... He seemed to know his way around the reader pretty well.
One thing he did say was the line pressure at idle was 5psi. But, neither of us know if that is within spec.
I talked to a local trans shop my dad has had good luck with and the truck is going in on Wednesday for a checkout. When I told the guy about it, he said it could be a major issue or a minor one but hard to say.
What I find kinda funny is that my neighbors who have 7.3 PSD/E4OD have chimed on on the issue saying its crap in the valve body or the MPLS. If there is crap in the body, to me that points to a bigger issue.
Just for fun I'm gonna take it by one of the parts houses and have them scan it tomorrow.
I'll keep the thread updated with my findings!
Thanks jk080 and gsmoljan for the reply and info!
Old 03-05-2011, 05:48 AM
line pressure
i think that i read that it showld be 65 psi in drive and before you send it to a trans shop ck craigslist you can always find a builder in there and a lot cheaper by me they only know 2000.00 at gibralter or lee miles but through craigs list found builder that wants only 750.00 so before you do it ck and they can tell you about better cluches and better parts dont forget a rebuild kit for your trans is only 235.00
Old 08-17-2014, 12:45 PM
Rodney Langley Rodney Langley is offline
Rodney Langley is starting off with a positive reputation.
My 95 F150 is doing the same thing. The difference is, I just had the front pump seal changed and it won't go into drive at all now. It was leaking really bad, but I filled it up with fluid, drove it a couple of hundred yards from my neighbors, had the seal replaced, and now it won't go in drive. Only reverse. It was driving fine before the seal change. Any ideas on something they could have messed up?
Old 08-19-2014, 08:09 AM
Also, how do you check the pressure? Is there a certain gauge/tool to use?
Old 08-19-2014, 12:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
To check pressure get a 0-350PSI gauge. There is a test port on the driver's side of the trans, just above the pan, towards the front of the trans.
Old 08-20-2014, 12:48 PM
New info: We fooled around with the truck again yesterday, checking connections on the tranny and such, and I drove it in reverse some on our drive (very bumpy). I switched into drive and felt it try to go in gear. I was able to get it to move forward VERY slow. (less than 5mph) I checked the fluid level and it had went down off the stick, so I added a couple of quarts and it brought it back up to the normal range. I thought maybe that would do the trick, but no improvement after that. Does this sound like something is stuck in the valve body? Is there anyway to resolve that without rebuilding the tranny?
Old 08-20-2014, 02:46 PM
It is definitely NOT anything electrical, nor is it in the valve body.
If it has enough fluid and the internal filter hasn't fallen out, then there is no way to fix this without a rebuild.
Old 08-23-2014, 09:36 AM
If the filter has fallen out, would that allow it to go in reverse, but barely move in drive?
Old 08-23-2014, 09:55 AM
No, it wouldn't work in drive or reverse.
Old 08-24-2014, 02:56 PM
Thanks for the reply. Any idea what may be the cause? As I said, it was driving and shifting fine before I parked it and had the front seal changed. Now, it only goes in reverse pretty much.
Old 08-24-2014, 08:56 PM
The shift linkage could be disconnected, either inside or outside of the transmission. Or the forward clutch could have failed.
m5od-r2 Reverse problems dawhits1 1987 - 1996 F150 & Larger F-Series Trucks 6 12-20-2012 09:07 AM
E40D 1st gear engages off and on timbuctooCal Clutch, Transmission, Differential, Axle & Transfer Case 6 11-15-2011 11:52 AM
Transmission slips after service... continues to shudder bentcipher 1999 to 2016 Super Duty 25 10-23-2010 10:29 PM
Has to be the wrong dipstick, right? E4OD Piginabag Clutch, Transmission, Differential, Axle & Transfer Case 2 04-24-2010 07:52 PM
97 E4OD No Reverse Only valiant500hp 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-14-2010 02:35 PM
Tags
1995, diesel, drive, e4od, f150, f250, ford, forward, hard, move, random, reverse, sifting, transmission, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
