Driver's front door sag
I,ve noticed recently that my driver's side front door has been sagging on the lock side and this is causing problems with it closing properly as well as sealing out air and noise. With the door closed the reveal between the door and front fender is noticeably smaller at the bottom than the top as well being tighter against the ext. cab door at the top than the bottom.
I looked at the hinges and bolts holding the hinges to the door and frame, I can't even get a wrench in there! Has anyone had this problem or know of a solution, as of right now the only thing I can think of is pulling the front fender and adjusting the the door by loosening the hinges and the re-torquing them, something I would really like the avoid doing....
If it is built like the OBS there should be 2 pins, one on the top one on the bottom. These doors seem to get heavier and heavier every yr, with all the electronics and Big mirrors, naturally they will wear. I have a co worker who has an 03 350, his were bad, I will check with him and see if he fixed it yet.
I would certainly appreciate it...just on first glance it looks like the fix will be a big PITA as I couldn't see a good way to get to the bolts holding to the hinges to the door and body respectively. It looks like I need to do something pretty soon too as the front bottom corner of the doors is almost pinching on the front fender...
boy oh boy, did them on a chevy s10 blazer it was sagging 1/4 - 1/2 inch. was a real bugger to close the door.. the trick i used was pull into garage, use 2 racheting straps thru door frame window to rafters to hold the door up when i pulled the pins to replace the bushings / pins
worked like a champ, i think the pins were only 5 bucks a set.at orielys auto parts
the hardest part was hanging the door from the rafters with the ratcheting strap, but it worked great, didnt have to disconect no wiring or nothing.
should work same for superduty
I've done this on other vehicles. I haven't looked at my truck yet because there has been no need. But per other vehicles...
You should be able to see the bushings around the hinge pins. Top and bottom of each pin. Ensure the bushing didn't drop out and allow the pin to distort/wear the hinge itself. If the hinge pin hole is out of round new pins/bushings will not align properly.
The door is heavy. Make sure you have help holding it in place if you can pop the pin out without unbolting the hinge. on my 76 Camaro I was able to use a 2X4 block on a jack to hold it in place while I popped one pin at a time to replace.
About to do this on my uncles OBS and found this video extremely helpful. It's on a ford thunderbird but the procedure would be the same. Well put together video.
YouTube - SAGGING CAR DOORS? FIX YOUR HINGE IN 30 MINUTES OR LESS.
