transmission oil change - Ford Truck Enthusiasts Forums
Old 03-03-2011, 10:04 PM
rileyruffen rileyruffen is offline
rileyruffen is starting off with a positive reputation.
i have a 2005 f150 4x4 4.6 with 100000 miles. i"m wanting to change my transmission fluild and filter, my dealer says all i need is to flush out the old and put in new ,which is what they do, they say no need to change the filter. anybody have any info on this?
Old 03-03-2011, 10:21 PM
sandrat's Avatar
sandrat sandrat is offline
sandrat is gaining momentum as a positive member of FTE.
I guess it's personal preference. Are you having an issues currently? If so, it's better to figure them out rather than just changing fluid and trying again. If you're not having issues, what I would do (and this is just me!) is drop the pan and change the filter, if for no other reason than to inspect the pan and see what's in there, for curiousities sake. I've heard differing opinions on which does a more complete job of changing fluid, and after using several different machines, some do better, some do worse. It might not change ALL the fluid, but if it's not in real bad shape, I'd do a pan drop and filter change. You can even do both if you really want to get all the old fluid out too.
Old 03-03-2011, 11:24 PM
dgndngrngr84's Avatar
dgndngrngr84 dgndngrngr84 is offline
dgndngrngr84 is starting off with a positive reputation.
^^^ great advice. With the pan off you can clean the magnet in the pan and better assess the condition of the fluid at that point too.
If you don't mind doing it yourself there is a great write up on here describing the complete process from dropping the pan to flushing out the fluid at the cooler lines in front. IMO not changing the transmission filter is like not changing the oil filter with an oil change. It's crappy that Ford techs don't do that as part of the flush. I bet they would if the transmission pan came stock with a drain plug. http://www.ford-trucks.com/forums/61...-schedule.html
Old 03-03-2011, 11:43 PM
oh and riley welcome to the site!
Old 03-04-2011, 01:48 PM
thanks guys, that was my thinking too, i always change the filter anytime i could, but the dealer said it really only a metal screen, and they could just flush it out. i not having any problems, so i think i drop the pan and change filter and what fluid i can.
Old 03-04-2011, 02:28 PM
Jr.Ranger-04 Jr.Ranger-04 is offline
Jr.Ranger-04 is starting off with a positive reputation.
Quote:
In my 04 it is a filter not just a screen I would change it that is the easiest part of the whole job is only about $20 for a new filter, has a re-usable gasket so putting the pan back on is a snap...
Transmission filter WXboy 2009 - 2014 F150 23 08-03-2016 10:23 AM
Transmission service question aphotic26 6.4L Power Stroke Diesel 7 06-18-2013 09:16 PM
2005 Escape transmission filter coreyp Escape & Escape Hybrid 3 01-30-2011 07:05 PM
In line Trans filter? Trans fluid change? Help Spool&Go 1999 - 2003 7.3L Power Stroke Diesel 9 11-21-2010 11:58 AM
Torqueshift Transmission Service? ozonekiller 6.0L Power Stroke Diesel 4 02-13-2004 12:28 PM
Tags
1965, 1996, 42l, c4, capasity, change, changing, f150, filter, fluid, ford, mustang, oil, transmission, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
