Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-03-2011, 08:28 PM
Robert_Mays Robert_Mays is offline
Garage is empty, add now
Robert_Mays is starting off with a positive reputation.
What would it take...?
if I wanted to add some wvo to my diesel just for the lubrication and to quieten the thing down some? A friend of mine has a fish restaurant and says I can have all I want of the waste oil so I was just wondering what all has to be done. i have looked at the threads but see either bio threads or 100% veg oil. I just would like to add maybe a couple gallons to each tank if that would do any good. If not, just tell me that LOL
Truck is a '99 7.3
  #2 (permalink)
Old 03-04-2011, 06:18 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
be sure to run it through filters before putting mixing with diesel , filter it down to around 1-5 microns and then take 2 gallons and mix with 2 gallons of diesel in a can or bucket before putting in your truck !
  #3 (permalink)
Old 03-04-2011, 10:58 PM
Do I need to worry about the water content?
  #4 (permalink)
Old 03-05-2011, 12:19 AM
binuya's Avatar
binuya binuya is offline
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
Quote:
Definitely! Moisture will destroy your injectors.
Here's another forum with plenty of info on how to handle wvo: Forums - Powered by Social Strata
But in my opinion, just dumping veg oil in your tank has too many potential problems. The biggest one being the risk of having it settle to the bottom of any part of your fuel system, and gumming things up. This is particularly an issue in cool weather. There are some who blend fuel and have it down to a science and can make it work, but there's a method.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #5 (permalink)
Old 03-05-2011, 09:55 AM
yeah I've been reading up on it quite a bit. It definately has potential. I have the oil source and a perfect place to put up the still down in my barn. I should really consider brewing my own fuel.
  #6 (permalink)
Old 03-05-2011, 10:22 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Think brewing is the way to go, no need to run two tanks or risk some of the other problems...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #7 (permalink)
Old 03-07-2011, 06:32 PM
Well, I think we are going to learn how to brew our own biodiesel. My wife and both parents are pharmacist so surely to goodness I can figure this out..
  #8 (permalink)
Old 03-07-2011, 07:29 PM
binuya's Avatar
I think it's the best route. You will do fine as long as you've got the motivation, space, time, and oil source. You have plenty of support here along with some seasoned veterans. It's complex, but not complicated. Best of all, it's a worthwhile, good thing to do.
__________________
  #9 (permalink)
Old 03-08-2011, 12:17 AM
muns53's Avatar
muns53 muns53 is offline
muns53 is starting off with a positive reputation.
Burning unheated WVO is a bad thing for your fuel system and your motor. In my picture album, I posted a chart with a viscosity table comparing diesel and veg oil - it doesn't come close until oil is at 160*F. This means it won't combust completely and will gum up your injectors, rings, etc. Also, with normal fuel blow-by on a cold start, you'll get veg oil mixed into your crank case - it forms a mayonaise-like substance inside; not good.
If you're looking for lubricity only, run a B5 blend, don't blend in WVO. In cold weather, it will drop out of the fuel and cause you the problems above. Bio is a lot more work and it costs more over the long run with the variable cost of methanol and the chemicals you need on an ongoing basis. But, bio shines if you do a lot of short trips or have multiple rigs to feed. Plus, you can run a B20 blend in your home heating oil if that's how you heat your home.
If you go the WVO route, convert your rig to a good heated 2-tank system like the Vegistroke. I'm not an expert, but I've been burning WVO in my '02 Ex with a modified V3 system for 2 years without major incident.
Either way (bio or WVO) if you have a good oil source, I don't think you can go wrong.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
