You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
More info....After checking my manual, your speedometer gets the speed information from (one of) the front hubs. There is a speed sensor located in the ABS system which gets the vehicle speed info from that front hub ring. So tire size will NOT make a speedometer change.
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family) Join the Maryland Chapter click HERE
You could also go to your local state police barracks and tell them you need to have your speedo checked. They will take you out to one of the local highways and have you run up to the speed limit and clock you with radar and let you know what they came up with so you can get it corrected. If I remember correctly it was free. Dan an 05 would have 4 wheel abs.
__________________
Shaun from MD
2009 F-150 Super Cab XL 4X4 4.6L 2Valve V8 My build thread.Added: N-Fab light bar, Rigid Industries LED lights,Rough Country hidden winch mount with Rough Country 9500lb winch. Up next: wheels and tires. Pending install Hell Bent Steel level kit. Big Bser number XO Slackmaster#5 Avid Winter Enthusiast!
__________________
Shaun from MD
Dutch ya beat me to it. I was thinking that when I read the header in the New Post's
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's 62 Uni 390 C6 Custom Cab Not Yet Sold
Looking to buy a 48/50 F Anything If ya have one contact me. Don't just Modify it Fordify it
Learned a great deal this past weekend at the tuning shop...
This is to the Diesel guys but I am fairly sure that it applies to the newer gas rigs as well. Speed is picked off the rear axle (tone ring within) on the 250-550 trucks and wheel size will modify what is seen on the gauge. If it were off the front ABS tone ring the speedo would not indicate an increase in speed when you rear tires slip. My 05 and current 08 indicate wheel spin at the speedo.
Something else to look with electronic transmission programming the power train module does take into account wheel size in it's calculations to adjust /make shift points and timing thereof. This may ( or may not) create issues down the road. With my rig it will cause soem issues with timing of shifts.
__________________
'08 450 King Ranch
Few Mods with a few to go.....
A simpler and cheaper idea to check speed:
1. Check based on Miles posts on highway... 60MPH = 1 mile per min.
2. Use a had held GPS and measure ground speed over a fixed distance and speed. Instanttanious measurements are ofter incorrect but if you let it integrate over time say 3-5 minutes you should get a fairly steady reading.
__________________
'08 450 King Ranch
Bud...... Increase in overall diameter will decrease what is displayed on the speedo gauge. It is purely a mechanical thing
While the tone ring is still the same diameter there will be no change to the system input however, the larger tire will travel further with each revolution thus your indicated speed will be slower than actual = a government donation and an accumulation of award points........ Not a good thing and will not hold up in court.
If you take that argument to court it will end up getting you more reward points and another donation for faulty equipment..... Not advisable take my word on that one.
__________________
'08 450 King Ranch
I apologize, now that you said it, I do remember that fact. And I should know better.....when I plug in my tuner, it gives me the chance to correct that error if I install larger wheels/tires.
I did tell you about the road markers tho.....
__________________
