'11 exhaust fitting? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-03-2011, 07:07 PM
Menghi08LT's Avatar
Menghi08LT Menghi08LT is offline
Menghi08LT is starting off with a positive reputation.
I've done a lot of research on this topic and can't draw a conclusion. I'm going to assume this applies to '10 and earlier models with the V10 engines as one of the exhausts matches that fitting.
I just picked up a 2011 F250, 6.2 V8 and it's a regular cab/8ft box, 137" wheelbase. I had a Magnaflow exhaust on my previous truck, a 5.4, but have not found any that would fit for this truck yet, minus the crew cab. Corsa and Gibson both make an exhaust they say fits extended and crew cabs starting with the Ext./short bed configs. It's a longer wheelbase. Banks' website lists this as the same exhaust for the V10 model, so I've even looked into that.
I contacted Corsa, Gibson, and Magnaflow about their exhausts listing specific part numbers and my problem. Gibson was the only one to respond, and it's been a week now. I was told in the email that in the past they would work together, but he cannot guarantee that it'll fit on my truck if I order one of the two that I would like, both of which are listed for ex/crew cabs. I was told to call my dealership and compare part numbers for OEM exhausts and if they match it should fit.
What I want to know is, are ext cab and crew cabs close or the same as the regular cabs? I have the extra money now for an exhaust and this truck is just itching for one!
Thanks guys!
Old 03-03-2011, 07:22 PM
bangin nails bangin nails is offline
bangin nails is starting off with a positive reputation.
I know on my 06 350 all were the same part # the difference in cab le ngths is made up by the factory mid pipe
Old 03-03-2011, 09:04 PM
KOESTNER's Avatar
KOESTNER KOESTNER is offline
Illinois Chapter LDR
KOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputationKOESTNER has a superb reputation
Thanks guys!
Change just the muffler with the same length,inlet and outlet location, and pipe diameter, the system is already stainless steel.
Old 03-05-2011, 09:01 AM
RZAR's Avatar
RZAR RZAR is offline
RZAR is gaining momentum as a positive member of FTE.
I have a Regular cab also. The exhaust is different from the SC and CC's. On our RC's their is one less resonator (a very Small one) than the SC and CC's.
Old 03-05-2011, 10:11 AM
rzar I dont think i have a resonator on my o6 ,mine has a cat on each down tube of the y pipe is yours a different set up?
Old 03-05-2011, 11:10 AM
RZAR's Avatar
Mine is a 2011 so it probably is
Old 03-05-2011, 11:20 AM
rzar not 2 jack this thread what do you think of the 6.2 I wouldnt call my 5.4 fast but in a pinch I pulled our kobota k 161 3 excavator and was surpised how well it did seeing as I have 3.73 gears so I can imagine that the 6.2 must be awsome!
Old 03-05-2011, 11:25 PM
RZAR's Avatar
Mine has the 6.2 with 4.30's and it moves! I only have 2000 miles on it. havent had the chance to really hual anythig heavy.
2009 exhaust systems cash188 2009 - 2014 F150 17 03-14-2010 09:37 PM
Gibson header thoughts V10man Modular V10 (6.8l) 1 01-28-2006 07:23 AM
Which exhaust do you have? FTE Trigger 2004 - 2008 F150 14 08-05-2005 11:18 PM
Exhaust question 98Cobra 2004 - 2008 F150 11 01-03-2005 04:54 PM
2004 F250...ext cab LB exhaust!!! 4x4bronco92 Exhaust Systems 0 10-22-2004 05:23 PM
Tags
2011, 62, banks, corsa, duty, exhaust, f150, factory, fit, gibson, parts, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
