Need to replace crush sleeve in 10.25... HELP
Hey guys, over spring break im going to be replacing the crush sleeve in my 89's 10.25 FF rear axle. Has anyone done this before, and if so, can you give me a step by step, or maybe a link to one? Ive got a pretty good idea what needs to be done, but ive never been this deep into this particular axle before. Also, are there any specific tools ill need to take things apart/ put back together? Thanks for any help!
You will need to fabricate something to hold the pinion while you are tightening the pinion nut. You will also need a large impact gun or a really long breaker bar for leverage to start collapsing the crush collar.
I used a long piece of angle iron as the starting point when I made my pinion holder. Ground out a half moon section to clear the pinion nut and two holes to attach it to the pinion flange. To tighten the pinion nut I used a 3 foot breaker bar with a 4 foot length of tubing to get more leverage.
An inch-pound torque wrench is required to properly set the preload. I came into possession of one of those jewels about 30 years ago when I used to do small engine repair. On the beer scale it's about a 12 pack job.
Would that work? Why or why not?
Thanks!
X2....fab your own pinion holder from a three foot piece of angle iron. Less than $10 at the local hardware store. I still have mine from 12+ years ago.
Thanks for the reply. Having the carrier installed adds about 3-5 inch lbs to the preload spec. Most people just account for that when setting the preload. The point about the holding power of the brakes is good though.
Also, it would be necessary to remove the brake drums when measuring the preload. Then put them back on again.
It might be time to fab a holding bar.
Any other thoughts on this job would be much appreciated.
Thanks again.
Thanks again.
Proper way is to gut everything in the housing, put new pinion bearings on, new crush sleeve and new yoke if your old one is loose, then torque to the required setting and reassemble. If you leave anything connected your going to get an inaccurate preload setting. Remember the carrier has a preload and the wheel bearings too and you can't properly account for those so remove them from the equation.
Proper way is to gut everything in the housing, put new pinion bearings on, new crush sleeve and new yoke if your old one is loose, then torque to the required setting and reassemble. If you leave the anything connected your going to get an inaccurate preload setting. Remember the carrier has a preload and the wheel bearings too and you can't properly account for those so remove them from the equation.
