Need to replace crush sleeve in 10.25... HELP
on
The yoke has been loose, the splines are now worn and loose, replace the yoke and pinion or it will just happen again ...
And don't use a crush collar ... Use a Ford 9" crush collar eliminator and you will never have the issue again! Of course that applies with the new yoke and pinion, Nothing will keep it together if you don't replace them!
You might get lucky just replacing the yoke with a NEW one, it is softer than the pinion and thus wears more.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
bart f-350
50
02-13-2018 04:20 PM
brian42
07-08-2017 05:36 PM
robbv
04-24-2017 11:40 PM
