72 f100 ranger xlt
72 f100 ranger xlt
Hi everybody im new to this . i have a 72 f100 swb 302 c6 transmission power brakes power steering . i switched from three speed on column to c6 now when i put it in reverse or drive it stalls fresh carb new fuel pump and filter new gaskest on carb and intake new cap and rotor new distributer new vacuum lines new plugs and wires cant fin any vacuum leaks not sure about timing put back just as it was with tdc if someone could help i would be grateful i bought my son a 02 lightning and he laughs at me cause my truck stalls every time i put in gear the rpm's are at 1200 in park then drops to 0 as soon as i put in drive thanks.
Stalls ? (engines sputters/struggles then dies) or shuts down?
If your idle is 1200 (which seems kind of high; I'm at 750 on mine) there is no way the trans can cause enough loading to kill the engine unless you have serious issues with the intake/ignition systems.
If it just shuts down when you select P or R then I'd be checking the wiring pretty carefully. Did you put in a neutral safety switch? That should only affect the starter but I've seen stranger things happen on conversions.
Timing is easy to adjust, at least. I'm not familiar enough with the Autolite carbs to offer any suggestions on a lean condition specific to the carb; I would suggest checking the fuel pump and filter to make sure you're getting a solid flow of fuel up to the carb before getting too involved in troubleshooting it. My '72 ran kind of odd one day (seemed down on power) then the next time I went to use it, it wouldn't start at all - turned out to be because the fuel pump was toast.
Sorry to everyone who tried to help me
I had a close family member pass away and it was hard to deal with but im getting better i still have the same problem with my truck 72 f100 302 with c6 tranny new filter and b&m shift kit and cleaned out really good came out of 69 f100 . i have put a new holley 3310 carb new k&N AIR FILTER fuel filter fuel pump fuel lines new distributer cap roter wires plugs new coil and replaced wires to coil new tranny vacuum modulator all new vacuum lines new intake gaskets i need help thank you and sorry .
no vaccum leaks? do u have a stock cam, if u have a big cam u might need a bigger powervalve in the carb, my 84 chevy swb would do the same thing and i put a vaccum guage on it and as soon as it put it in gear the vaccum dropped and it woould die, powervalve fixed it, might not fix urs but its just a suggestion
84GOAT300i6
10-09-2013 01:41 PM
Marc82390
04-22-2011 11:28 AM
MintHill68f100
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
20
10-30-2005 01:26 PM
