EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
real world mpg in ecoboost 4x4
Old 03-03-2011, 11:05 AM
diver110's Avatar
diver110
diver110 is offline
Are there enough ecoboost 4x4's out there to get some real world mpg figures city and highway?
Old 03-03-2011, 12:16 PM
drh1175's Avatar
drh1175
drh1175 is offline
At this time I would say no. But when I get mine and have driven a bit I will be sure to post!
Old 03-03-2011, 12:32 PM
EdCaffreyMS's Avatar
EdCaffreyMS
EdCaffreyMS is offline
The EBs are just now trickling in, so the wait for "real world" input shouldn't be too far down the road. Mine is due in next week, and I'll certainly be happy to post my MPGs.
I would anticipate that these engines will get better MPG once the engine is broken in...likely the MPG will peak sometime after the first oil change...at least that's what I anticipate.
Old 03-03-2011, 06:14 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,219 Likes on 802 Posts
https://www.ford-trucks.com/forums/1...xperience.html
Read my post about my drive. The Ford rep averaged 17-19 from Detroit to Virginia in a 4x4 King Ranch 3.5L.
Old 03-03-2011, 06:47 PM
excaliber551's Avatar
excaliber551
excaliber551 is offline
Our neighbors best friend say he's getting almost 16 MPG in mostly Freeway not Highway driving with a bit of city mixed in. The truck has 2500 miles on it.
Lariat EB 4X4 3.73 SCREW 6.5' bed.
Old 03-03-2011, 08:02 PM
tseekins's Avatar
tseekins
tseekins is offline
According to the Ford rep, the 4x2 EB trucks with the 3.31 axle are getting mid 20's on the hwy.
Again guys, we need to see real world numbers from folks that have all applications of this truck and engine. This will take some time as it's all pretty new.
Old 03-03-2011, 11:18 PM
boomer08's Avatar
boomer08
boomer08 is offline
I have filled up twice in a week and a half but it hasn't gotten too far under 3/4 of a tank when I filled it up. I am getting mid 12's doing all of city driving. Filled up today and went to KC and back and it showed 16.1. It should get better as I put miles on it. (I hope).
Old 03-05-2011, 02:26 PM
Bronco_Lee's Avatar
Bronco_Lee
Bronco_Lee is offline
12s? 16 on highway? Man that's not looking very good. The one I test drove was showing 22 mpg on the highway cruising 75 or so. I didn't do much city driving but now I'm wondering if I should drive one more stop and go before I order one this week...
The truck I drove was 2011 Supercrew 4x2 XLT 5.5' bed 3.15 gears Ecoboost.
Old 03-05-2011, 03:43 PM
excaliber551
12 and 16 is pretty much what I have been seeing too. I took an EB for a ride today on a 90 mile round trip. This truck with just under 4000 miles on it.
I wanted to really give it a test at 75 MPH on the Freeway.
With the truck cruising at 75 mph it averaged 14.7 mpg. The early part was slightly uphill but mostly flat. I still don't see how these are going to get 21MPG.
Old 03-05-2011, 04:14 PM
tseekins's Avatar
tseekins
tseekins is offline
As I said in another post, the 4x4's with the 3.73 or 4.10 axles won't get 21. The 3.7L 4x4 truck with 3.73's is rated for 21 and I doubt it will get it.
Old 03-05-2011, 04:20 PM
Bronco_Lee's Avatar
Bronco_Lee
What setup were you driving? The one I drove was pretty easy to get 20 mpg + on the computer. I even hit punched it a couple times and it got back to over 20. I got over 20 after exiting and driving around a little bit too so seems weird. I wonder if there's a wide variance in mpg on these trucks? Will make me a bit upset if I order one and get one that gets bad mileage. The truck I drove had 1 mile on it before I put 30-40 on it that day btw...
Old 03-05-2011, 05:13 PM
excaliber551
I'm not sure what is going on either but it's been the same in all the EB's we've driven so far.
This was a Lariat 4X4 EB Screw 3:73-1 with the 6.5' bed. The owner is thinking of selling it already so we wanted to test it at freeway speeds to really see what the story was.
This was a pretty good test to see how it would do on the freeway at true freeway speeds. The engine is awesome and the truck is really nice but the MPG's seem way off.
Has anyone towed with this setup yet? I'm really curious what MPG they are getting.
tseekins's Avatar
tseekins
tseekins is offline
If mpg's are your main concern then you should be very cognizant over the axle ratios and opt for the 3.31 or the even the 3.15 axle. The engine will pull these trucks with a taller axle you just won't have the max tow or payload capabilities.
Gas mileage is a hot button issue right and as it should be. But we have to be realistic with our choices.
Old 03-05-2011, 05:27 PM
Bronco_Lee's Avatar
Bronco_Lee
I've been looking at 3.55 and 3.31 axle ratios so that's likely part of the difference. I don't tow very often but I drive a lot of stop and go. This truck will be used for our swimming pool maintenance business btw. So lots of short distances...
Old 03-06-2011, 08:45 AM
msalyer's Avatar
msalyer
msalyer is offline
These milage figures seem low to me. My 2001 F250, 5.4, 4speed OD auto, 4:10 geared, SC, 4x4 weighing 6500 lbs will get 14 (hand Calculated) cruising the highway @ 70.
The lighter, new technology, 6speed equiped F150 SHOULD get considerably better IMO.
Quick Reply: real world mpg in ecoboost 4x4
