Transfer Case Seal Replacement - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 03-02-2011, 10:08 PM
NemesisNJ NemesisNJ is offline
NemesisNJ is starting off with a positive reputation.
Just looked at the Repair Guide Member section on Autozone's site and it says I can replace the front output shaft seal by removing the shaft and yoke from the bore. It also says this for the rear seal as well. But I just picked up a Haynes Manual and it states I can only do this for the rear, and the front seal replacement requires me to drop the transfer case from the trans and disassemble it. Anyone ever replaced the front output shaft seal? Any guidance would be greatly appreciated.
Old 03-04-2011, 09:29 AM
dirtmonkey11's Avatar
dirtmonkey11 dirtmonkey11 is offline
dirtmonkey11 is starting off with a positive reputation.
I personally haven't done the transfer case seals on these trucks before, but one thing I would do is look at a factory Ford service manual that is specific to your truck. I have a Haynes manual and it sometimes is too broad on the explanations and fixes. Don't get me wrong it’s a good manual, but when you need to get very specific info I found the factory service manuals to be more helpful. I'm sorry I couldn’t be more helpful.
77 F150 NP 205 transfer case leaks mjr46 1973 - 1979 F-100 & Larger F-Series Trucks 13 07-27-2016 04:29 PM
transfer case output seals jbehuniak 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-19-2016 07:01 PM
NP 208 oil seals ranscobia 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 10-14-2015 06:22 PM
transfer case output shaft seal pdqtimetrialer 1978 - 1996 Big Bronco 1 09-08-2011 07:07 PM
BW4406 Front Seal Leak jbezzy 1997-2006 Expedition & Navigator 4 03-25-2010 10:58 PM
Tags
2001, 97, case, cost, expedition, f150, f250, ford, front, leak, output, replace, seal, seals, shaft, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
