General Diesel Discussion
Oil Testing
Old 03-02-2011, 09:23 PM
auden's Avatar
auden
auden is offline
Oil Testing
I am in the Pheonix (Surprise) area and would like to hear some suggestions as to where to have my engine oil sample tested. I am on my second change of Rotella t-6 and would like to take in one or two sample's in the next week or so. 7.3 Diesel. Thanks for help.
Old 03-02-2011, 09:33 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
I can't help you with a local source, but I've used Blackstone Labs for a few years. Costs around 22 bucks a sample plus postage, and you can usually see your results online in about a week.
Here's a link to their website: Blackstone Labs
Old 03-02-2011, 10:09 PM
76ranger's Avatar
76ranger
76ranger is offline
i have to ask what is the reason for testing used oil ive never heard of this before, what can be found from testing the oil
Old 03-02-2011, 11:24 PM
binuya's Avatar
binuya
binuya is offline
I send an oil sample to Blackstone for analysis at my normal oil change interval of 5k miles. In particular, 7.3 Powerstrokes are hard on oil due to the nature of the high pressure oil pump which in turn, activates the injectors (despite the huge oil capacity of 15 qts). For example, at around 5k miles, my oil (15w-40 Delo 400) shears down to a 30w. You don't want to go any lower than that. But as in all other engines, the oil analysis will tell you about the presence of certain wear metals such as lead, iron, aluminum, chromium, and some others, which can be a good indicator of areas which might be wearing excessively, (i.e. bearings, piston rings, camshafts, etc.) The analysis also lets you know about the level of protective additives and detergents.
What I look for are particular trends in certain areas, such as a big increases in iron deposits which would indicate either exessive cylinder bore or camshaft wear. I make and run biodiesel, so I also want to know if I am getting any crankcase dilution.
For me it's totally worth the $24 per test. I plan to keep my rig for a long time. It's a great way to know the internal health of your engine.
Old 03-03-2011, 11:18 AM
bashby's Avatar
bashby
bashby is offline
I've heard of some trucking companies doing oil analysis instead of changing at certain mileage intervals. It would be interesting to know how many miles it takes to actually wear out your oil.
Old 03-03-2011, 01:03 PM
senix's Avatar
senix
senix is offline
Received 1,410 Likes on 1,006 Posts
On older non emissions diesels on OA is the way to go.
Newer emissions diesels and OA is till usefully to pin-point problems early but extended oil change intervals is not a wise decision.
I use blackstone as well.
bigb56
12-12-2014 05:49 AM
KC8QVO
6.7L Power Stroke Diesel
07-29-2011 03:55 PM
BigRyan
10-15-2008 02:39 PM
adambomb
Bio-diesel, Propane & Alternative Diesel Engine Fuels
23
07-09-2008 09:38 AM
Heckler
09-17-2004 10:30 AM
Quick Reply: Oil Testing
